06-11-2005, 01:28 PM | #1 |
Premium Level Member
Safety vs Original - Brakes and Roll bars
-Currently I am running the original front drum setup on my 69. Seem to work good. Many people have changed to the disk setup, but are the drums really that unsafe? I really want to keep the factory setup, but don't want brake failure either!
-Also, I really enjoy the look of the classic blazer (69) as it came without the rollbar. I also know this is not the safest if a rollover occured. But I only use for street driving so what are the chances. Thoughts?
69 K5 CST stock- 350, 4speed 77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's, |
06-11-2005, 01:47 PM | #2 |
Drums brakes are no more unsafe then disc. Just that disc have more stopping power.
Rollbar-how many cars with the top down have you seen with a rollbar?
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
06-11-2005, 01:48 PM | #3 |
Why is it not the safest in a roll over? Because a 6 or 8 point bar is stronger? Ok i agree.... But as far as 4 point bars go..... i'm not understanding?
The only time they wouldnt be safe is if they're not installed correctly.... - which is probably most of the time. Out of all those of you who have roll bars.... how many have backing plates under the tub? (under the wheel wells and up front where the bolts poke through.) If you just use a nut and washer there ( like most!) then yes - when and if you roll - the roll bar will TEAR right out.... If you use backing plates so the nuts and washers cant pull through.... then i'd imagine you're doing OK. This is my case.... as i dont do any major wheeling... but i love cruising the fire roads around here and like all the CDF trucks - i got my roll bar too. Seat belts is another story Last edited by Medicanman71; 06-11-2005 at 01:49 PM. |
06-11-2005, 06:23 PM | #4 |
Agree with Jhow66.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
06-11-2005, 08:48 PM | #5 | |
I agree with ya jakeslim, I like the looks without also. I have mine installed because of my kids. |
06-12-2005, 03:22 AM | #6 |
I'm still trying to finish the power disc brake conversion (from manual drums) on my '69, but since the goal is to tow with the truck it is necessary. I can't afford to have crappy brakes towing either my boat or my trail rig hooked to the rear of the Blazer.
I will be adding a rollbar to mine as well, I want to also take it to the beach a time or two and run around on the nicer weekends without a top on. If it's done right it will look clean and factory. Same with the brakes. Only a die-hard fan would know that the stuff was not original. Make the truck meet YOUR needs. |
06-12-2005, 08:27 AM | #7 |
The LuvShack Garage
My $.02 for whatever it is worth
2WD - Blazers and Jimmy's - NO BAR 4WD - Blazers and Jimmy's -
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
