wipers won't work
i have checked the fuse as well as the power wire, and they still don't work, what else other than a worn out motor could it be?
Aaron |
Was they working and just stopped?
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
#3 | |
no, I just got it. Aaron |
What model truck?
![]() Join Date: Nov 2003
If you have power too them I would guess you hav a bad motor. It's fairly common to have those motors die. They really aren't tough to replace, just time consuming.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
I have also seen the switch die. (mine)
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
#7 | |
Orange Truck
![]() Join Date: Jun 2005
senior member
i buy a new switch every spring so far ive gone thru 6 of them they work for a couple weeks then quit so now i have wipers but only when i push the button in for the sprayers
69 GMC bagged |
I also have to hold the button in. I tried 3 used switches with the same results. Could they all be bad? If I reach under the dash and touch the right wire just right they work. I have replaced the plug and all wires look to be in great shape.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
#10 | |
Thank you for the replies, how would I check the switch? Where is the wiper motor? 1970 Chevrolet C/10 Aaron |
I make Models
![]() Join Date: May 2005
Wiper motor is on the interior side of the firewall behind your dash.....if you look up under your dash you will see it. Not real easy to get to.
![]() Last edited by knsmodels; 06-15-2005 at 01:50 AM. |
