Old 06-11-2005, 01:49 PM   #1
Andrew68c10
El Camino Rear Ends Fit in Our Trucks?
I was just told that any rear end from a 69 thru 71 El Camino will fit in our trucks. Can anyone verify that? I thought they would be narrower or at least have smaller brake assemblies, so I've assumed they wouldn't work. Am I wrong?
1968 Chevy C10 Longbed Fleetside
Andrew68c10 is offline   Reply With Quote
Old 06-11-2005, 03:25 PM   #2
cdowns
cdowns's Avatar
open the tailgate b-4 putting it in and you shouldn't have a problem
Old 06-11-2005, 03:36 PM   #3
Ogier
Chopper/Painter
Ogier's Avatar
Keep in mind that the El Camino is basically a station wagon with a bed...
Do you want a car axle in your truck???
With regards,
Ogier
1969 Chevrolet C20 - Resto-Custom started!!!
Ogier is offline   Reply With Quote
Old 06-11-2005, 03:48 PM   #4
I don`t know that they have the same mounting dimensions as trucks(trailing arms/shocks).I also don`t know what the benefit would be.Probably narrower,too.And,yes,smaller brakes.Are you thinking of your C/20?I`m planning on installing a Dana60 from a C/20 in place of the 12-bolt in my short bed.There are parts available to use 5-lug axles/brakes.Not narrowing/tubbing,just want a beefy third member to handle big hp.
Old 06-11-2005, 03:53 PM   #5
MARIOS68PANEL
Active Member
MARIOS68PANEL's Avatar
Now thats funny
67 short step
71 Custom
MARIOS68PANEL is offline   Reply With Quote
Old 06-11-2005, 06:50 PM   #6
Andrew68c10
I'm switching from 3/4 ton to 1/2 ton. I need a 12 bolt with coil spring perches.
And I have a long bed, so I won't need to open the tailgate.
Old 06-11-2005, 07:21 PM   #7
JimKshortstep4x4
Talking
The brackets that are welded to the rear end are completely different and the brakes are different. There may be a way to adapt it but you are better off finding a truck rear end. The wheel bolt circle is 5 on 4 3/4".
The El Camino rear ends are like the Chevelle rear ends.
Jim
Old 06-11-2005, 09:29 PM   #8
hotrodmtodd
'Burban Legend
hotrodmtodd's Avatar
Left Coaster
Andrew,
I wish you lived in PA instead of CA, I would gladly trade you the correct rear-end for an A-body rear-end. Chevelle, El Camino, Cutlass, Skylark and Le Mans are all A-body cars and they are DEFINITELY different from our trucks in nearly every way. The brake shoe retainer springs might be the same, that's about it. You have to admit the tailgate thing was pretty funny. Take care, Hot Rod
'67 Chevy Iron City Beer Truck (9ft step)
'67 Chevy Panel Truck 467
'68 Short Fleet 305v6
'68 McLaren Ramp Truck
'68/'68/'70/'71 Burbs 292/366/402/454
'69 C-30 dump
'71 C-50 dump and church bus
'71 4x4 454
'72 Blazer (w/pop-up camper) $15 x-hooks
'66 Chevy II 194/Weber
'68 El Camino" 305v6
'69 Skylark 455 Buick
'70 Chevelle 427
'71 Cutlass W-31
'71 GTO 400 2x2
"The 51" Chopped '51 Chevy (409) my first car
OK Toad, we'll take 'em all... John Milner
hotrodmtodd is offline   Reply With Quote
