Old 06-11-2005, 04:55 PM   #1
Goffer
Goffer's Avatar
Question Frame Rail Tranny Cooler?
I'm wanting to put in a rail trans cooler. It's summer time in Phx, and it just doesn't seem like the radiator will cut it any more. I'm looking for coolers that you all use and have been happy with. Any other suggestions are welcome as well.
'71 C10 swb 350sb/700r4
Goffer is offline   Reply With Quote
Old 06-11-2005, 06:03 PM   #2
Goffer
Goffer's Avatar
What is the size of the female fitting for the trans lines on a standard radiator?
Old 06-11-2005, 11:56 PM   #3
pjmoreland
pjmoreland's Avatar
1/2-20. It's not NPT.
pjmoreland is online now   Reply With Quote
Old 06-11-2005, 11:59 PM   #4
pjmoreland
pjmoreland's Avatar
Hayden makes a fitting set that includes one barb fitting that threads into the radiator, and one barb fitting that threads onto the end of the OEM steel cooler line from the transmission. You can run flexible hose from the barb fittings to a transmission cooler. The part number is 393. I recently bought this at PepBoys.
