Old 06-11-2005, 10:26 PM   #1
4bynut
4bynut's Avatar
Please help w/ motor size
I have a v8 in a 69-70 GMC 1/2 ton I'm parting and I need help trying to decide what it is. The #'s on the block aren't listed in the book I have. The # on the back of the block is: 10066038 and on the front of the block by the head it is: MAI 9353. The glove box door list it as a 296 v8 which I've never heard of. Thank's in advance, Jason
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans.
2001 Chevy ZR2 Ext. cab 4x4 (DD)
1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process)
1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project)
4bynut is offline   Reply With Quote
Old 06-11-2005, 10:31 PM   #2
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
My best guess is that it's a mis-print on the decal, and the engine is actually a 396 big block.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 06-11-2005, 10:35 PM   #3
Randy70C-10
Randy70C-10's Avatar
10066038...350.....92....4...Goodwrench crate motor, 2-piece rear
seal, "Hecho en Mexico" http://www.mortec.com/castnum.htm
Randy70C-10 is offline   Reply With Quote
Old 06-11-2005, 10:38 PM   #4
Big Bad 1972 Blazer
Big Bad 1972 Blazer's Avatar
Here's what I dug up from my info on the casting number from the block....10066038...350.....92....4...Goodwrench crate motor, 2-piece rear seal, "Hecho en Mexico"
Looks like the motor probably was swapped out at some point in it's life.
Big Bad 1972 Blazer is offline   Reply With Quote
Old 06-12-2005, 01:01 AM   #5
4bynut
4bynut's Avatar
Thank's for your help guy's. I really appreciate it. Do you know if them are good. I seem to remember hearing something about problems with the GM motors from mexico. But I don't know if it was just certian years. Also would it be a four bolt main block? Thank's again Jason
Old 06-12-2005, 05:42 AM   #6
JimKshortstep4x4
Talking
Mortec lists the engine as having 4 bolt mains.
Jim
Old 06-12-2005, 10:13 AM   #7
Randy70C-10
The Mexican engines were called "Targetmasters". They were built with some heavy-duty parts and put together quite well. You shouldn't have any problems with that engine.
Old 06-12-2005, 11:09 AM   #8
70short/step
70short/step's Avatar
By the look of that list on your glove box door......Sounds like it has a lot of goodies that people want! Posi, Tach, AC.....
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
