Old 06-12-2005, 01:37 AM   #1
Jakes-66-K10
Jakes-66-K10's Avatar
How to zero speedometer?
Hey guys, been working on this all night. I know there's gotta be an easier way. I know now how to dissamble the whole thing (had an extra speedo to practice on.)
Before I tried disassembly I did hookup a speedometer cable and reverse the direction of the drill. No go. It will go one direction, but seems to have a safety in it to prevent the gears from going the opposite way.
So the best I have found is to remove the roll of numbers and then you can start rolling them back by hand. But after 3 hours and only loosing 10000 miles this is going to take forever! What's the trick to this?
Jakes-66-K10 is offline   Reply With Quote
Old 06-12-2005, 06:01 AM   #2
RED72blazer
urban fourwheelin
RED72blazer's Avatar
why not just use the drill and spin it forward back to zero
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 06-12-2005, 09:40 AM   #3
lamar
lamar's Avatar
Speedo zero
If you have the odometer wheel out just hold it in your left hand with fingers holding the first metal tab(left to right) and turn the gear with other hand until you have 9 in the ten thousand place. Then just keep holding the first metal tab and now hold the second metal and turn until you have 99***. Then you do the same for the rest until 99999. Then I just reinstall the wheel and then turn the speedo by hand a few turns until 00000. Hope that helps. If not let me know.
72 C-10
lamar is offline   Reply With Quote
Old 06-12-2005, 10:24 PM   #4
kelsfine69
18 Till I Die
kelsfine69's Avatar
Its kinda like a rubics cube
kelsfine69 is offline   Reply With Quote
Old 06-13-2005, 12:14 AM   #5
Jakes-66-K10
I got it, thanks for your help guys!
