Old 06-12-2005, 04:34 PM   #1
skokie
skokie's Avatar
What did you get done this weekend?
I havent seen one of these in a while so here we go.
I changed the oil in the truck and cleaned up the driveway.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 06-12-2005, 04:46 PM   #2
HerLonghorn71
HerLonghorn71's Avatar
Nadda it was too wet and windy and just plain crappy to do anything!
HerLonghorn71 is offline   Reply With Quote
Old 06-12-2005, 05:01 PM   #3
cdowns
cdowns's Avatar
gave myself a headache
Old 06-12-2005, 05:08 PM   #4
Harold Shepard
Not this weekend, but this week got the new SB 327 running- and it sounds great- and I also got the blazer tank in place, now to run lines and locate a filler door/ tube to complete the install. Hopefully I will get brake hoses this week and all I will have to get are calipers to finish the rolling chassis and then back to body work.
Harold Shepard is offline   Reply With Quote
Old 06-12-2005, 05:16 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Finished up the lift install on the blazer some yard work and finally signed the paper's on my new house that I am having built and a garage is part of the deal so no more carport for me........
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 06-12-2005, 05:17 PM   #6
Nima
Blue 67
Drained and replace transfer case and gearbox oil. Boy!, transfer case oil was look like sludge!, it might have been original!!.
Nima is offline   Reply With Quote
Old 06-12-2005, 05:44 PM   #7
Tim240Z
Tim240Z's Avatar
A good bit: http://67-72chevytrucks.com/vboard/s....php3?t=159857
1972 Suburban C20
454/TH700R4, eaton-corporate 4.10 (looking for 3.7)
Sold: 71 Cheyenne 20
Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005)
Tim240Z is offline   Reply With Quote
Old 06-12-2005, 05:49 PM   #8
402Bowtie
402Bowtie's Avatar
I put over 2000 miles on my '97 when I picked up my rust free '72 bed from Albuquerque, NM this week.
402Bowtie is offline   Reply With Quote
Old 06-12-2005, 05:57 PM   #9
hgs_notes
GEARHEAD
hgs_notes's Avatar
Got about 2/3 of my exhaust in, waiting till monday for a couple parts. Replaced spark plugs, did some tuning on the holley and reset timing.
Started replacing soffits on the house, took the kids swimming and fishing. Tonight I'm taking my boy to the races.
HG
hgs_notes is offline   Reply With Quote
Old 06-12-2005, 06:09 PM   #10
70GMCer
70GMCer's Avatar
I got 1 sbc head ported and polished........man, I'll be glad when these heads are done........Now I know why machine shops charge so much.....Want to get this motor/trans together and back into the truck so bad......
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 06-12-2005, 06:14 PM   #11
72MARIO
72MARIO's Avatar
Well lots.
Blasted the junky boxing paint off the shorty headders . Painted them with VHT flame proof paint flat black. I used stainless headder bolts to make them look a little better. Ran 3" dual manderal to Super 40's by flowmaster. Mounted my Autometer Water + Oil pressure gauges. Changed My water neck to a polished swivel neck so I could use the water port for my Painless Fan wiring switch. Installed the Lokar shift linkage. Installed my carb with 1" spacer and a new T.V cable. Finished the stainless brake lines. And just going to finish the Ebrake cables. Grounded the body/motor to the frame.
Should have it running by next weekend.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 06-12-2005, 06:24 PM   #12
Alex Hayley
Checked and increased the thrust bearing clearance of the engine I am building.
edit: and looking at the image, I can see that the indicator is NOT parallel to the axis of the crankshaft...have to redo that measurement.
Alex Hayley is offline   Reply With Quote
Old 06-12-2005, 06:29 PM   #13
Old Dave
Is a bullfrog waterproof?
Old Dave's Avatar
Watched it rain. We've had about 10 inches in a week.
"It is better to remain silent and be thought a fool, than to open one's mouth and remove all doubt."
Ben Franklin
1970 Chevy shortbed
2002 Harley Custom Chopper (Long sucker)
1998 K2500 5.7L 5-speed Longbed
1st two are My son's toys...they just live in my garage!
1997 GMC K1500 Suburban
1993 S-10 Blazer 4D (youngest son's daily driver)
2000 Dodge Ram 4WD Ext. Cab (5.9L)
Wife is a late year 1951
Old Dave is offline   Reply With Quote
Old 06-12-2005, 06:38 PM   #14
Long Roof
Old School, New Style
Long Roof's Avatar
Waxed my burb, built a charity dog house for the local Humane Society, worked a little on software installs at work, and lounged in the air cond.
I'm still waiting on the 3"/4" drop and seat belts for the burb, it's on back order.
Aaron
The Good:
- 72 GMC Jimmy 4x4 - 307 cid / 350 th
- 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th
- 96 Chevy Impala SS - mainly stock
- 98 Chevy Tahoe LT 4x4 - all stock
The Bad:
- 86 Chevy Suburban 1/2T 4x4 - winter beater
The Ugly:
- 72 Chevy Suburban 1/2T 2wd - parts truck
Long Roof is offline   Reply With Quote
Old 06-12-2005, 06:41 PM   #15
Hart_Rod
Hart_Rod's Avatar
Installed a hidden hitch, air tank and compressor for my BAGS on my 69 Burb.
Hart_Rod is offline   Reply With Quote
Old 06-12-2005, 07:29 PM   #16
mocwon
Keep On Truckin'
mocwon's Avatar
Wiring, wiring, wiring..
Took the plenum off to cover the fuel injection wires with split wiring loom along with all other wires in the engine compartment. Finished up engine compartment wiring for Vintage Air (still have to plumb it). Re-located battery wiring to passenger side. Tucked headlight harness below raidator so its hidden as much as possible. Did I mention I hate wiring?
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 06-12-2005, 08:06 PM   #17
jamis
F.A.S.T. president
jamis's Avatar
Stop raining for half a day and got to mow the lawn. Cleaned the garage some. Burned some DVDs and watched about 10 episodes season 5 of the Sapranos.
@Alex Hayley
Nice crank with lightning holes, cant tell if you knife edged the counter weights. Thats a big help if your going to spin the hell out of it. Wouldnt worry about the position of the diel indicater, that angle couldn't make more the .0005 of a diffrence. I like running about .007 to .010 of thrust clearnce. Some say its critical but I havent seen to many failures, except when they dont line up the thrust surfaces correctly.
F.A.S.T. President and Founder
Fabricators for the Advancement of Sawsall Technology
"A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis"
jamis is offline   Reply With Quote
Old 06-12-2005, 08:06 PM   #18
Alexis
Member since 2000
Alexis's Avatar
http://67-72chevytrucks.com/vboard/s....php3?t=159744 <----what i didon britney
Today, sunday, I did the brakes on my mom business Van. It's the van her workers take to do there job so the brakes seem to take a toll with all the driving up and down hill.
Alexis is offline   Reply With Quote
Old 06-12-2005, 08:26 PM   #19
68haywagon
I'm watching you!
I finally got my truck up to Wilkes-Barre . It made the 135mi trip without a hiccup. Learned a few things along the way though...fuel gauge is off and so is the speedo .
Now to start working in it
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 06-12-2005, 09:02 PM   #20
Between yesterday and today I pulled my old passenger door off, rebuilt the original hinges, then used them to hang the replacement door. The drain holes hand been welded over on both my replacement doors, so I made new ones on both doors. Cleaned and coated them as well as the inside of the doors and the door bottoms with eastwood. Also stripped the passenger side of the cab and painted the floor with eastwood., as welll as some spots on the driver's side. Spent the rest of today checking out and working on a replacement motor for my 30 year old snapper. Pretty productive overall.
Old 06-12-2005, 09:15 PM   #21
70 shorty
Where's my beer?
70 shorty's Avatar
Went to the VA picnic yesterday, got in a mountain bike ride on the trails before everyone got there, crashed when I got home. Worked a couple of OT hours today, did a complete detail on my mom's car, my folks are coming back from a european vacation tomorrow, and cleaning her car is my mothers day present since she wasn't here for mothers day. Also replaced the valve cover on the truck since it leaked like crazy going to the picnic yesterday.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 06-12-2005, 09:21 PM   #22
hilljob26
hilljob26's Avatar
i got about 75% done on my painless wiring and finally after 6 months since it was dynod,i fired it for the first time in the truck,WHAT A RUSH.got the headlight working,and the wipers work,still have alot of loose ends.
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 06-12-2005, 09:41 PM   #23
dwaite72lnghrn
I fired up the new engine. I could not wait for the serpintine setup so I put the old on the new just to hear it run. Sounds GOOOOD. The old air compressor just won't mount up with the new dipstick. All of the new tapped holes in the block and heads are 7/16 and not 3/8 like the old so I had to open up the mounting brackets to get the alternator on. Then had to tackel the relay setup for the electric pump and all of the new 3/8 fuel lines. At about 4:00pm I run in the new engine for 20 minutes at 2500rpm. Really want to get on the road again, I feel like a caged animal without wheels. Once the first 500 miles are on it I can tow the bug down for a paint job. then we will have 4 out of 5 on the road and I can start on the GMC brakes and get that on the road.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 06-12-2005, 09:49 PM   #24
armyavncowgirl
C10 Junkie
armyavncowgirl's Avatar
my trucks immobile. powersteering is being installed. tough one, have had to do a number of modifications to get it all to fit. right now i'm at the point where the pulley is making contact with the fan so we have to get an adapter for it or buy the electric fans. thats all thats left and then i can put her back on the road again.
09 Chevrolet HHR --- Cruck --- cross between a Car and a Truck
Former rides:
1967 C10 LWB
1972 C10 LWB
1969 C10 LWB (parts truck)
armyavncowgirl is offline   Reply With Quote
Old 06-12-2005, 10:23 PM   #25
knsmodels
I make Models
knsmodels's Avatar
where to begin....friday night drove 2hrs each way to see 71c1068cad in Harrisburg as he had a part I needed for my seat frame (nice guy, first board member I met face to face) got home like 1 am.....Sat. delivered aforementioned part to upholster so he can finish my seat. Sun....got the front end sheetmetal lined up on my K10 and got the wiper valance back in place...also got the dyno mat installed in the cab.....Hope to have truck back to road worthy within the next two weeks....I will post pics when done...overall pretty productive I think....Paul
Click to see what I do
1972 LWB K10 350/4 sp
1968 SS Chevelle 396/tremac5spd
knsmodels is offline   Reply With Quote
