Old 06-12-2005, 10:38 PM   #1
new271
new271's Avatar
What Posi unit will fit?
Hey Guys,
Anyone know what vehicle posi unit will work in my carrier?I have a 71 chevy c10 ,swb, shortbed,307,3 speed,coil spring 12 bolt rear.I think that should be all the info.If you need more let me know.
Mike
new271 is offline   Reply With Quote
Old 06-12-2005, 11:43 PM   #2
Green Machine
Green Machine's Avatar
If you are keeping your current ring and pinion, you will need to get the gear ratio also. I'm goint to guess it would be a 3.07 ratio. Gear ratio determines whether you need a 3 series or 4 series posi carrier. I beleive the split is at 3.73, that is 3.73 and higher numerically like 4.11, 4.56 use the "4' series carrier, and the 3.42 and lower numeriacally like 3.07 use the "3" series carrier, someone correct me if I am wrong. That same type rear was used from mid 60's to late 70's in trucks , no car swap available IIRC.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
