06-12-2005, 11:48 PM | #1 |
Left Foot Functioning
Speedometer Noise
Hey gang,
Could use some advice on the '69. My son is finally driving it around town, and the only problem to show up so far is an intermittent noise from the speedometer. Definitely does it longer and more often at higher speeds; a vibrating/buzzing noise (no speed warning ). Noise disappears completely when we disconnect the speedo. The needle does nothing special during the noise - steady and smooth. Any thoughts/advice? Thanks...SSOW
69 C10 (#1 son's ride) 72 C20 (Dad's farm truck) 82 K30 (Ex - brush pumper project) |
06-13-2005, 12:15 AM | #2 |
It's a catastrophic success.
Unhook it from the tranny,pull the inner cable out of the outer sleeve,check it for wear,clean it,lubricate it,and put it back together.they gum up and get dry and it causes the to twitch going down the road.
06-13-2005, 03:11 AM | #3 |
Its Magically Delicious
does ATF come pouring out when you unhook the speedo from the tranny ??
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
06-13-2005, 04:12 AM | #4 |
^ No the gear drive for the speedo that goes into the tranny housing shd retain the tranny fluid (on the manual trannies anyway). I went through a simular ticking noise with a S-15 GMC I once owned, I thought it was coming from the head (on the 4 cyl.)but it turned out to be the small gear box that the speedo cable attaches to (at tranny) almost drove me bonkers figuring it out. I pulled it off cleaned it out, regreased everthing, reinstalled it and problem fixed. Doug
06-13-2005, 09:07 AM | #5 |
Thanks, guys....we'll pull, clean & lube it asap. Sure beats pulling the speedo.
I want to remember the white lithium grease as the weapon of choice in this situation. Is that right? While we're at it, does the small gear box at the tranny need to be lubed, and if so, how? SSOW
06-13-2005, 10:27 AM | #6 |
white lithium grease will do ok ,but i prefer the speedo cable lube as it does a better job and doesn't gumup it's graphite based and actually polishes the cable as it's beind used. it's available in most autoparts stores
06-13-2005, 11:02 AM | #7 |
you will get some tranny fluid leaking out on a auto trans when you remove the speedo gear.
71 C10 SWB BLACK AND WHITE 350 CRATE TH350 ENJOY LIFE |
06-15-2005, 07:26 AM | #8 |
1969 Custom 30 wrecker
To lube a speedometer cable, I've always just "fished" the cable into a quart of trans fluid, then pull out while lightly wiping off the excess and reinstall. I never had a problem using this method.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
06-15-2005, 07:42 AM | #9 |
67-72 Addict!
When I pulled my bullet out it leaked alot of fluid into a bucket I had. I think I should have jacked the rear of the truck up to keep the fluid toward the front.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
