Old 06-13-2005, 12:24 PM   #1
Jakes-66-K10
Jakes-66-K10's Avatar
Symptoms of a bad tach?
How do you know if you have a bad tach? I scored one from a junkyard the other day (along with lots of other cool finds) and this weekend hooked up everything.
This tach kinda works. It "peaks" but won't drop back down. For instance, At first it peaked at idle, I'd rev up the engine and the needle would climb but wouldn't come down. So it sticks wherever the highest RPM setting was.
I wouldn't be suprised if I hooked things up wrong though. The distributor hookup and the tach hookup I'm pretty sure I got right but I may have hooked power up to the wrong spot in the fuse box. I'll have to check when I get home... would this cause a symptom like this?
Jakes-66-K10 is offline   Reply With Quote
Old 06-13-2005, 04:59 PM   #2
Jakes-66-K10
Bump. No one has seen a problem like this?
Old 06-13-2005, 05:29 PM   #3
jtminton
II Timothy 4:2
jtminton's Avatar
Mine seems to stick at zero on acceleration, then jump over and read really high.
72 C-20 2WD LWB Custom Camper Deluxe 350 4 Speed "Project Lazarus"
MY TRUE PRIDE AND JOY
"Dangit, Bobby, people will see that oil stain and think I'm a drunk."
jtminton is offline   Reply With Quote
Old 06-13-2005, 06:16 PM   #4
too much stuff
Roadtrip!
too much stuff's Avatar
I had 2 of them do that, but they seemed to loosen up with more use. I think they get sticky if they sit for awhile. I think if you hooked it up wrong, it wouldn't work at all.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 06-13-2005, 08:39 PM   #5
Jakes-66-K10
OK. Just to make sure, where do you plug it in at the fuse box?
