Old 06-13-2005, 05:01 PM   #1
68jimmy
68jimmy's Avatar
700r4 required with TPI?
Is a 700r4 or 4l60e required when doing a TPI swap? Is anyone out there running a th350 with TPI?
Thanks!
78 C10 LWB Super Cheyenne
68jimmy is offline   Reply With Quote
Old 06-13-2005, 05:54 PM   #2
Russell
Professional Grade
Russell's Avatar
Nope, you can run any tranny you want. Simply pull the tranny lockup stuff off the harness and head on your way! The ECM does not look to see if the tranny locked up or not, so it will not care if you have it plugged in, or just sitting there.
Hang onto the lockup wiring though, incase you want to go to a lockup tranny later
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 06-13-2005, 07:55 PM   #3
71swb4x4
71swb4x4's Avatar
I am running my TPI with my 4-speed. I will be putting a 700r4 in this summer though.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-16-2005, 05:41 PM   #4
68jimmy
68jimmy's Avatar
Thanks, that's good to know...
Old 06-16-2005, 10:26 PM   #5
Deuce
Deuce's Avatar
I'm running a 700R4 in my truck, but you can run any tranny you want. jasonmorrow is running a turbo350 with his TPI.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
