Old 06-13-2005, 05:15 PM   #1
GlennBrittain
Another 700R4 Question
I have the 700R4 installation complete, with the exception of my tempature gauge. My problem is a leak at the rear tail shaft seal. My transmission builder, a buddy deal, said my front yoke does not go far enough into the transmission. I did measure the distance with my old transmission and with the new transmission installed. The measurements came out to be the 3” noted on several Internet sites on the subject. What I do not know is was the driveshaft the proper length to start with, since the previous owner pulled out the standard and installed the turbo 350.
Does any know what the distance the yoke should be inside the tail shaft? I would like to resolve that issue before replacing the seal. I plan to put my truck back up on stands, scribe the yoke at the seal the drop the driveshaft to see where I am at now. Unfortunately, my tractor is calling me to mow first and it is 101 degrees here today.
GlennBrittain is offline   Reply With Quote
Old 06-13-2005, 05:41 PM   #2
72MARIO
72MARIO's Avatar
The yoke should be around 3/4" out from the tailshaft of the tranny.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 06-14-2005, 11:55 PM   #3
GlennBrittain
I measured the yoke this afternoon, after running a new wire for my distb. I have 1 1/2" showing. The only other drive shafts I have for comparison are one that was pupped out of a standard and one still installed I6 and standard. If my yoke is the same length as the other shafts I have 2 1/4" inside the tailshaft. After wiping of the leaking fluid and watching, it looks like the leak is between the outer edge of the seal and the shaft housing.
Old 06-15-2005, 07:25 AM   #4
Hart_Rod
Hart_Rod's Avatar
3/4 to 1 inch should be good.
Rob
Hart_Rod is offline   Reply With Quote
Old 06-15-2005, 10:11 PM   #5
GlennBrittain
Thanks for the info
Old 06-15-2005, 10:20 PM   #6
Harold Shepard
The trans length on a three speed manual and th350 are the same length so you should be good on length, unless long shaft th350 .
Harold Shepard is offline   Reply With Quote
Old 06-15-2005, 10:35 PM   #7
BubbaGreen
FYI: some of the 700R4, the ones from cars are sometimes fitted with a "short" splined output shaft, the ones from trucks have "long" splined shafts. For the short version, its better to use the same yoke as a TH-350 trans. 1-1/2 out seems too far. 3/4 to 1" is correct. If the trans is used, it could be that the pressed in bronze bushing in the tail shaft itself is worn or the seal needs replaced.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
Old 06-16-2005, 10:33 AM   #8
1-PU70
1-PU70's Avatar
If you replace the seal I would replace the bushing too or you just might be wasting your time.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
