Old 06-13-2005, 08:19 PM   #1
72gmcshorty
72gmcshorty's Avatar
How much can I take apart.....
I'm getting the itch to tear apart my blazer. I'm wondering how much of it needs to stay together in order to rebuild the tub portion of the body. Is it ok to take off the front clip? Can the doors be removed? I know the top needs to stay on in order to do tub body work.
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 06-13-2005, 08:37 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
You can remove eveything if the rockers are solid, if not leave the top on
for sure, and if you're removing it from the frame I'd leave the doors on 2,
the front clip on the other hand can be removed without any issues.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 06-13-2005, 09:39 PM   #3
orangeuavol
GO VOLS!
orangeuavol's Avatar
Take a look at how I did it, see the link in my signature.
http://1972blazer.shutterfly.com/<= blazer build pics
It's called golf because all the other four letter words were taken.
It's easier to ask for forgiveness than for permission.
orangeuavol is offline   Reply With Quote
Old 06-13-2005, 09:40 PM   #4
vtblazer
vtblazer's Avatar
If the top is left on and is bolted down correctly, removing the doors won't bother anything. Everything should stay lined up okay.
That guy's just being cautious.
vtblazer is offline   Reply With Quote
Old 06-13-2005, 09:50 PM   #5
Medicanman71
Medicanman71's Avatar
how do the doors keep things lined up? What about the blazers w/ no doors and no top mobbing around?
Medicanman71 is offline   Reply With Quote
Old 06-13-2005, 09:54 PM   #6
vtblazer
vtblazer's Avatar
That's what the torsion boxes are there for.
Even if the torsion boxes are in good shape, keeping everything lined up is important if removing or replacing body parts, especially if you remove the tub from the frame.
Old 06-14-2005, 10:20 AM   #7
mastercraftkpk
If you're thinking about restoring your truck frame-off, leave everything on....brace and cross brace areas like the door frames, top of A-pillar area(bottom of windshield), etc... by welding steel tubing across these areas.
With this done, you can remove everything that you will need to remove to get to damaged areas without having everything flex/move around.
They are not "insurgents"...they're vermin, cowards, and terrorists.
Egon..." I think that they are more interested in my epipedimus."
mastercraftkpk is offline   Reply With Quote
Old 06-14-2005, 05:40 PM   #8
JMac11
JMac11's Avatar
Wow.....
Your photos make me very afraid to take anything apart on mine. I was like wow, that is a nice blue blazer and now he is restoring one..... till I put it together.... Great job....
JMac11 is offline   Reply With Quote
Old 06-14-2005, 08:58 PM   #9
orangeuavol
GO VOLS!
Thanks. It was a "20 footer" when I got it, as in it looked good from 20 feet. The PO did a lot of work to just hide the bad.
Old 06-17-2005, 06:18 PM   #10
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Well, I went the complete opposite route. I tore everything apart. Every seam was split, every piece taken apart. I'm in the Gulf right now, so its still in pieces, but at last update, the driver side bedside was reassembled and reinstalled. Got to finish the passenger bedside, reskin the doors and finish the reassembly. So far, putting it back together has not been bad, just took some pushing and pulling to get it all to line back up again. Once I have the tub reassembled, I'll use the welded in rods to pull the tub back into square before tacking the bedsides in place. Really its up to you as to how much work you want to do. I know that the way I have done it is really labor intensive, but I'll be happy with the finished product. Want some real work, look at what GeeEmm has done. Good luck, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 06-17-2005, 06:52 PM   #11
vtblazer
vtblazer's Avatar
Even the floor seam below the firewall?
Now that's an intense resto!
