427
69 c/60 with 427,Have not seen one of these before with 427 emblems on hood. How common were these? Do these motors have potential? Is it worth $800.
The 366 and 427's that came in those trucks are tall-deck engines. They were designed for low rpm's and high torque, and all of them had a carb mounted governor that would shut the engine down after 65 I think. Not sure exactly what is worth 800 bucks, is it just the engine, or a whole truck? Does it run?
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
Its the whole truck with no bed on it and it ran when parked.
68cst_ss490
if the engine is gooits worth the 800 bucks. those engines are crazy man. you can build a wicked bigblock stroker out of them. they have the extra deck height which is good. they make an adapter for aftermarket intakes so you can use almost and intake. plus they are even making aftermarket intakes for tall decks. the new 572 block is a tall deck 10.200 deck height. and they build mega amounts of hp and torque
thats just my 2 cents
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
Thanks, i thought i read somewhere about the truck 427 havin potential.
800 bucks ain't bad. With the right mods you oughtta get some mega horsepower out of that 427.
Just know that if you are going to Build a Screamin 427 stroker, It will cost a few bucks to do it. The tall deck is a Great motor to build and would be worth the $800 as stated above. Just wanted you to know the cost to build it! They Rock when done right!
For every person with a spark of genius, There are a hundred with ignition trouble. ![]() |
'Burban Legend
![]() Join Date: Apr 2005
Cab Condition?
I might be interested in the cab (whole front end actually) if it is in decent shape, cheap, and semi-local. Where are you in these United States? Might get you back a little of your investment? Let me know, Hot Rod
'67 Chevy Iron City Beer Truck (9ft step) '67 Chevy Panel Truck 467 '68 Short Fleet 305v6 '68 McLaren Ramp Truck '68/'68/'70/'71 Burbs 292/366/402/454 '69 C-30 dump '71 C-50 dump and church bus '71 4x4 454 '72 Blazer (w/pop-up camper) $15 x-hooks '66 Chevy II 194/Weber '68 El Camino" 305v6 '69 Skylark 455 Buick '70 Chevelle 427 '71 Cutlass W-31 '71 GTO 400 2x2 "The 51" Chopped '51 Chevy (409) my first car OK Toad, we'll take 'em all... John Milner |
its all about the +6 inches
IIRC, you'll be in it for 10K by the time you turn it into a mountian moter.
One awsome thing is though, it'll have a steel crank, that'll fit in a normal 427. |
'Burban Legend
ttt
