Old 06-13-2005, 09:52 PM   #1
JoeMamma
JoeMamma's Avatar
'67 C10 Antenna Question
Hi,
I just picked up a '67 C10 that was not equipped with a factory radio. The antenna mounting hole on the top/right side of the fresh air cowl is not drilled out. I also don't know where to pass the antenna cable through body sheetmetal and into the passenger compartment. I pulled the glovebox and couldn't find any existing holes or rubber grommets on either the firewall, the air cowl or the door pillar.
Could someone take a measurement of their own antenna base and let me know where to drill the fresh air cowl? Any idea where the cable enters the passenger compartment?
Thanks,
JoeMamma
JoeMamma is offline   Reply With Quote
Old 06-13-2005, 10:00 PM   #2
70c10
67-72 Addict!
70c10's Avatar
JoeMamma, welcome from Maryland!. Do yourself a favor and sell that "factory" shaved cowl to someone looking for that look. They can bring decent money sometimes. You can easily find a cowl in a junkyard that already has the correct hole located in it. The hole is drilled below the cowl opening and the cable runs along the inside firewall above the heater box to the radio.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 06-13-2005, 10:06 PM   #3
screamin_c102
screamin_c102's Avatar
I spent alot of time and money to shave the external antenna from Screamin'. That shaved cowl would have been worth some bucks to me. Find yourself another cowl at the wrecker and post that one for sale on the board.
screamin_c102 is offline   Reply With Quote
Old 06-13-2005, 10:11 PM   #4
Mongo
YES_____NO
Mongo's Avatar
Very good advice.
hell someone one the board might have a cowl that they will sell you.
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown
Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984
Help support the board
Mongo is offline   Reply With Quote
Old 06-13-2005, 10:45 PM   #5
JoeMamma
JoeMamma's Avatar
Thanks guys!
The truck had an interior mounted antenna with a small amplifier. The kind you string under the IP. The radio only got in 1 AM station and 1 FM station, and the reception on these two stations was bad. I bought another one and installed it. After a lot of work (factory air), it improved slightly. Your correct about poking an unnecessary hole in that air cowl. Can you recommend an interior mounted antenna that doesn't need to be strung under the IP? Maybe something with a small mast that can be mounted vertically behind one of the seats?
Thanks Again,
JoeMamma
Old 06-13-2005, 10:53 PM   #6
72402
I've got a short rubber(or something similar) antenna between the headliner and roof on my streetrod. It works great. You might try that under the dash. Frank
72 Cheyenne SWB Fleet/original 402, TH400, buckets & console
65 C10, 350TBI, 700R4 (work in progress)
72402 is offline   Reply With Quote
Old 06-13-2005, 10:59 PM   #7
JoeMamma
JoeMamma's Avatar
This is why I really don't want to poke a hole in the cowl.
Old 06-13-2005, 11:38 PM   #8
67sss
67sss's Avatar
WOW! Love those 67's..................
67sss is offline   Reply With Quote
Old 06-14-2005, 01:41 AM   #9
laid67c10
laid67c10's Avatar
if you want to swap for one with a antenna hole let me know i'll swap you......
49 Chevy - currently under construction being bagged and hunting for a LS drivetrain!!!
09 - Harley nighttrain on air ride!
laid67c10 is offline   Reply With Quote
Old 06-14-2005, 04:39 AM   #10
'68OrangeSunshine
'68OrangeSunshine's Avatar
I fit a "rubber ducky" AM/FM antenna onto the passenger side rear view mirror of my '67 Sub. Worked great. I snaked the cable under the ventwindow rubber grommet.
Old 06-14-2005, 01:10 PM   #11
lilred67
lilred67's Avatar
dakota digital makes an under the dash electronic antenna.i'm looking at putting one in my '67.
lilred67 is offline   Reply With Quote
