Stock Tach Hook up How ?
It's a HEI. Stock Tachfor points I have no wiring just the clip to hold the wire in the cap. Could you please specify how to hook it up colour and gauge of wire ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
What kind of tach?
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
The stock tach wiring is pink for the positive hookup and it plugs into the ignition "unfused" location on the fuse panel. The wire to the distributor is brown and both wires are a 14 gage. The brown wire to the distributor plugs into the "Tach" terminal on the HEI.
The tach gets its ground through the case when it is fastened to the dash bezel. Jim Last edited by JimKshortstep4x4; 06-14-2005 at 07:27 AM. |
