Old 06-14-2005, 09:44 AM   #1
Syco67
Question How far could you lower a truck for free?
Well maybe not entirely for free. My sister would like to lower the 69, not too earth scraping levels, but just enough so the tires fill the wheel wells a little better. I have heard talk of cutting coils, and removing leaves from the rear. How low could you get the front with cutting the coils before it couldn't be aligned properly? If we were to get a lowering kit, what would it be comprised of? How hard would it be to go from the top pic to the bottom pic? thanks again to whoever chopped this pic for me.
If at first you don't succed, break something!
Syco67 is offline   Reply With Quote
Old 06-14-2005, 10:10 AM   #2
boraxman
Keepin an eye out
boraxman's Avatar
I wouldnt go more than a 3-5".
I actually had this, front cut and rear heated. I bought new dropped springs and the ride is about the same.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 06-14-2005, 11:01 AM   #3
mer316
anytime you go cutting on springs and such can cause troubles. I would look into a kit that would keep everything alined
Robby
mer316 is offline   Reply With Quote
Old 06-14-2005, 11:06 AM   #4
dubie
dubie's Avatar
you can lower the truck by 2" all the way around by cutting 1 coil off each front coil spring and then installing 2" lowering blocks in the rear to drop the back end
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 06-14-2005, 02:32 PM   #5
shifty
Questionable
shifty's Avatar
You're supposed to increase the tension of the spring 15% for every one inch you remove.
If you cut the coil, you're reducing the size of the spring, but not increasing the stiffness. The more you cut, the bouncier your ride will be and the more you risk damaging your vehicle.
Lowered springs are really cheap and so are blocks. I'd consider lowered springs in the front and blocks in the back.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 06-14-2005, 02:50 PM   #6
tomatocity
tomatocity's Avatar
LMC has a chart that shows the different stages of lowering. If you have the money I would add 2.5" drop spindles and 4" lowered rear springs. The drop spindles keeps the same front suspension and the best lowered ride. The 4" lowered springs will work but are borderline whether you should notch the frame.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 06-14-2005, 08:30 PM   #7
silvertonguedevil
silvertonguedevil's Avatar
A friend of mine dropped his approx 6 inches all the way around by cutting the ends off of two trailing arms and putting them on top of his trailing arms and then heating the coils. He said that it still aligned and he can still pull a trailer.
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
Old 06-14-2005, 09:58 PM   #8
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
Originally Posted by silvertonguedevil
A friend of mine dropped his approx 6 inches all the way around by cutting the ends off of two trailing arms and putting them on top of his trailing arms :
That is just basically a real cheap way of putting blocks on the back, and lower the back end whatever that height of the trailing arms are.
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 06-14-2005, 11:32 PM   #9
pissonNOS
senior member
pissonNOS's Avatar
lots of people cut down the idea of lowering by cutting but i did it a year and a half ago and havent had a single problem to date and the ride is no more bouncier now that it ever was
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 06-15-2005, 12:37 AM   #10
modifiedGMC
Here's mine I just dropped about 3" in rear and about 2 to 2 1/2" front. I cut 1 1/4 coils up front and heated the rears. Mine actually feels like it rides better than before dropping. I still got to get front end alignment but basically drives good.
If it don't fit, force it,...If it still don't fit , modify it 'till it does fit !!!
modifiedGMC is offline   Reply With Quote
Old 06-15-2005, 01:39 AM   #11
BowTieMan
BowTieMan's Avatar
Can I use any lowering blocks or do I need certain blocks?
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 06-15-2005, 09:33 AM   #12
Syco67
Would't I have to use an axle flip kit to use lowering blocks? This is a spring over setup. Maybe there are some blocks in there I can remove now. My sister ran off with the truck so I can't check right now. I was gonna check the LMC catalog, but my sister ran off with that too . Does anyone make dropped spindles for trucks with front drum brakes?
Old 06-15-2005, 08:33 PM   #13
BowTieMan
BowTieMan's Avatar
Here is the rear. See where the block would go? Between the arm and the axle.
Old 06-15-2005, 10:08 PM   #14
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
leaf spring or coil rear.you metion leafs in youre first post and everybody else is talking coil rear.some of these did come with leaf rears.
if its leaf rears then youre looking at a axle flip and c notch frame 5-6 inches
or you could remove some of the leafs from the pack
or lowering shackels which will be 1-2 inches
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 06-16-2005, 01:11 AM   #15
71Dragtruck
71Dragtruck's Avatar
AHH yes the mighty edit button
71Dragtruck is offline   Reply With Quote
Old 06-16-2005, 06:08 AM   #16
Yes,you can buy drop spindles for drum-types.You can buy drop control arms,too.On the rear,try less leafs/low shackles.You may not need c-notch then.
Old 06-16-2005, 09:49 PM   #17
jhah71chevy
jhah71chevy's Avatar
Iwould like to know where to get some drop spindles for drum brakes also!!!!
JEREMY HUDSON
jhah71chevy is offline   Reply With Quote
Old 06-17-2005, 12:54 AM   #18
FirstGen
Just Don't Stop!
FirstGen's Avatar
where are you guys getting the lowering block kits from?
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 06-18-2005, 04:27 PM   #19
Syco67
Yeah, it's got the leaf sprung rear. Didn't all the old old GMC's have leaves and the chevy's had coils, or is it the 1/2 tons had coils and the 3/4, 1 ton trucks had leaves? Where would I look for the drop spindles?
Old 06-18-2005, 08:47 PM   #20
bigred66
bigred66's Avatar
http://www.classicperform.com/6092ch...ing-block-kits (were i got mine very nice looking kit)
http://www.gmcpauls.com/67-72_d&s.htm and http://www.performancesuspension.com/TruckLowerTwo.htm
and i think these http://www.stockcarproducts.com/trkarm1.htm would work
Atom (bigRed66)
1966- C10
1995- Wide Body Talon
1987- Dodge Raider (4 sale)
2000- 4-door Nissan Frontier
2003- Ford Focus (wife)
bigred66 is offline   Reply With Quote
Old 06-19-2005, 10:19 AM   #21
modifiedGMC
Not all of them. My 69 GMC has coils and my wifes dad's 70 or 71 has leafs. Both are 1/2 ton trucks.
Old 06-19-2005, 08:18 PM   #22
swissfacade
swissfacade's Avatar
Check out CPP's site
This site has a large selection of high quality parts at a fair price
the following items will only cost you $242.00 and lower your truck 3" in front and 3-4" in the back safely.
Front: 3" lowered springs
Rear: 2" lowering blocks and 1-2" Drop shackles
Lower your leaf spring truck the easy way with a set of drop shackles. Designed to bolt in place of the stock shackles. These units give you the choice of either 1" drop or 2" drop. Shackles come painted with polyurethane bushings installed.
Then just enjoy the ride
swissfacade is offline   Reply With Quote
Old 06-21-2005, 08:52 PM   #23
Fat Tom
For those of you that have heated your rear coils, did you just heat up one or two coils, or try to evenly heat all of them? Did you use a rosebud tip or regular cutting torch tip?
69 GMC 2wd 350cid
82 Toyota 4wd, 3.8L V6, 6" lift, 35's, locked and loaded
76 Datsun F10 1.4L ***FOR SALE***
04 Honda Shadow 750
Fat Tom is offline   Reply With Quote
Old 06-22-2005, 12:47 AM   #24
modifiedGMC
I used a regular tip and heated the bottom coil until thefirst touched the arm then heated the top coil until it touched the frame. Be sure to stop heating BEFORE you get to where you want it because truck will continue to drop some after removing the heat.
