Old 06-14-2005, 06:29 PM   #1
JQ-72
JQ-72's Avatar
Dwell setting???
What's the best way to set the dwell in the points when you don't have a dwell meter? Can you adjust it while its running and listen for anything? Thanks for any help.
Joshua
JQ-72 is offline   Reply With Quote
Old 06-14-2005, 06:36 PM   #2
70GMCer
70GMCer's Avatar
Years ago, and I mean many years ago, I used to adjust the point gap with a piece of matchbook cover. That was before I was able to buy a dwell meter. That always worked for me.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 06-14-2005, 07:11 PM   #3
cdowns
cdowns's Avatar
with the cap off bump the motor over to get it so the points ramp is on the highest point ov the dizzy cam and use a feeler gauge to set the points at .019" if they're new p[oints or .016"gap if the points are used
Old 06-15-2005, 06:10 AM   #4
GMC AMI
GMC AMI's Avatar
Wink
Giving away your age with that one!
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 06-15-2005, 07:06 PM   #5
bagged91
Out draggin'
bagged91's Avatar
Exactly... The matchbook method works in a pinch too
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 06-15-2005, 07:28 PM   #6
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Don't forget to reset your timing after setting the dwell since it affects the timing. I know you probably already know this but just thought I would mention it.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 06-15-2005, 08:32 PM   #7
john
member #16
john's Avatar
Joshua
Another method that has been around for years, is to adjust while running you turn the adj. screw in until it starts to misfire and then back it out 1/2 turn. You can check with dwell meter and it will be about 30 degrees dwell. John
john is offline   Reply With Quote
Old 06-15-2005, 08:38 PM   #8
tomatocity
tomatocity's Avatar
Agree with 70GMCer. We must be the same era.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
