Old 06-14-2005, 06:56 PM   #1
OlyHeeebz
NP205 oil seals are hard to locate???
One of the 2 rubber seals that goes inside the adapter between the TH350 tranny and NP205 in my truck has gone bad, and oil and trans fluid are sloshing back and forth.
To my surprise, the local GM dealer in my area can not seem to locate the seals. In fact, they can't even cross reference them to find out which ones to order. There are little numbers on the seals and everything, and the guys behind the counter still can't figure it out.
Anybody know where to buy these seals? Or what the new GM parts number is?
1969 K5 Blazer CST
Always waiting for the Puget Sound sun.....
OlyHeeebz is offline   Reply With Quote
Old 06-14-2005, 09:22 PM   #2
Phuloi68
go to your local bearing supply place. they can supply them.
Phuloi68
Indy survivor
Norwood survivor
Big Sandy survivor
for those who fight for it...
F R E E D O M
has a price the protected
will never know.
Phuloi68 is offline   Reply With Quote
Old 06-14-2005, 11:40 PM   #3
Paso76GMCstepper
Paso76GMCstepper's Avatar
My local Napa had em for mine.
Also try here
www.nationaldrivetrain.com
Tony
"Life is a Team Sport"
To the memory of the Hendrick Motorsports Plane Crash Victims
Paso76GMCstepper is offline   Reply With Quote
Old 06-14-2005, 11:41 PM   #4
kwmech
I have the part numbers at work, hope I remember tomorrow.
Old 06-14-2005, 11:49 PM   #5
drink2mny
drink2mny's Avatar
We can ge them over here in Spokane...
Support The Board
drink2mny is offline   Reply With Quote
Old 06-15-2005, 05:15 AM   #6
4x4Poet
Yup, a bearing sales store will just pull or cross the p/ns on your seals.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 06-16-2005, 02:08 AM   #7
Richard
Make sure to check and probably replace the o-ring on the t-case input shaft. I have had two 350/205 setups that leaked from that seal not the ones directly in the adapter.
Richard
Old 06-17-2005, 08:48 AM   #8
teamroper!
teamroper!'s Avatar
tell your dealer to look in group 4.515. the part number 3979626 should be the seal that you require, but check your application with your dealer, Be sure and use a GM seal as I've not had good luck with aftermarket seals. The part number shows to fit just about everything GM makes that had a NP205.
teamroper! is offline   Reply With Quote
Old 06-21-2005, 08:42 AM   #9
HeavyK20
HeavyK20's Avatar
Try here: http://www.drivetrain.com/transfercasesparts.html#New
Eric
1969 K20, 465/205 package
HeavyK20 is offline   Reply With Quote
Old 06-21-2005, 12:39 PM   #10
stueber68
1968 C20 Vortec Beast
stueber68's Avatar
Do I see that another GM parts spec. is a member here? That's what I do.
stueber68 is offline   Reply With Quote
Old 06-21-2005, 12:56 PM   #11
teamroper!
teamroper!'s Avatar
stueber68, how long have you been at it?
Old 06-27-2005, 12:22 PM   #12
tgh117
Crazy
tgh117's Avatar
My dad hooked me up with this part number, and it turned out to be the transfer case shifter slide seals. The part number for the seal between my tcase and trans was 3968050. Its all back under the truck though, and now it doesnt leak
77 SB Stepside in a bunch of pieces scattered around the garage.
tgh117 is offline   Reply With Quote
