Old 06-14-2005, 08:36 PM   #1
Rodder4hire
Exclamation HELP! Need Q-Jet part and question.
Need a fast idle cam for a 74 truck/van carb (7044214). I need a fast idle cam.
Also - if you've got a 74 carb, does it have a secondary lockout lever behind the vacuum break / choke assy.
I'd be willing to buy a core if need be or just the cam and or lockout lever.
Thanks.
Rodder4hire is offline   Reply With Quote
Old 06-14-2005, 11:11 PM   #2
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
Yes, it will have the lock-out lever. Is that a 4MV carb? I might have the parts you need, just the ride to your door. Let me look, will let you know.
NeCrOmAnCeR is offline   Reply With Quote
Old 06-15-2005, 11:58 AM   #3
Brad_Olson
Active Member
Brad_Olson's Avatar
Correct, 7044214 is a 4MV. For some reason the secondary lockout gets lost every time I build a Q-Jet...
Brad
Brad_Olson is offline   Reply With Quote
