Old 06-15-2005, 11:08 AM   #1
SKYGOD
Hei Distributor Problem
I have a 1972 c-10 with a 350 V-8 that runs like a top, except::::, I am having trouble with the HEI distributor with the built in coil. I am now on my second internal coil and this one has stopped firing.
I believe I should replace the distributor with something more reliable! Has anyone had this problem and what resolution would you recommend?
MARK
SKYGOD is offline   Reply With Quote
Old 06-15-2005, 11:52 AM   #2
cdowns
cdowns's Avatar
bad ground or using original(resistor) wiring can both cause this problem
Old 06-15-2005, 12:44 PM   #3
71Dragtruck
71Dragtruck's Avatar
Try running a new power wire if you haven't allready. like cdowns said the original wire has a resistor in it.
71Dragtruck is offline   Reply With Quote
Old 06-15-2005, 01:47 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Hei probs
Go to the FAQS and read this thread.
http://67-72chevytrucks.com/vboard/s....php3?t=157669
http://67-72chevytrucks.com/vboard/s...d.php3?t=17403
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 06-15-2005, 02:30 PM   #5
shifty
Questionable
shifty's Avatar
If you don't ground your coil with a dedicated ground wire, you'll burn up your coil. Pictures of proper wiring, showing the given ground strap and the other ground strap you need to install:
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 06-15-2005, 02:40 PM   #6
tomatocity
tomatocity's Avatar
What happened to the original black wire in the above photo?
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 06-15-2005, 02:46 PM   #7
shifty
Questionable
shifty's Avatar
What do you mean?
Old 06-15-2005, 03:09 PM   #8
tomatocity
tomatocity's Avatar
top pic says to pull black wire (from coil) to hole. bottom pic shows an additional black wire being installed from the connector to the frame around the coil. what happened to the balck coil wire that was pulled to the hole?
What do you mean?
Old 06-15-2005, 03:31 PM   #9
shifty
Questionable
shifty's Avatar
It's still there, but because I shot from a different angle, the plug wire obscures the loop connector on the smaller black wire and the yellow wire obscures where it leaves the coil. If you look closely between the yellow wire and the plug wire to the left of the coil cover tab, you'll see the middle of the small black wire there. I can circle it if you want - it's directly below the letter "G"
Old 06-15-2005, 04:09 PM   #10
67ChevyRedneck
67ChevyRedneck's Avatar
The black ground strap in the second picture can also be an actual all metal strap that runs to the same two places. I don't have pics, but that's what I got off an HEI DIZZY in a 'yard. My truck was missing the strap in the second pic and I fried my module and coil. No problems anymore.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 06-15-2005, 05:12 PM   #11
tomatocity
tomatocity's Avatar
Is the black wire from the coil connected to anywhere other than the coil? After you say 'pull the black wire to the hole' you don't sat what to do with teh black wire. Is it connect to the bracket, using a bolt, that holds the coil?
Old 06-15-2005, 05:16 PM   #12
tomatocity
tomatocity's Avatar
I am forgetting to be courteous. Thank you for providing the instruction with pictures. You say 'pull black wire to hole' but you don't say what to do with the black wire after it is pulled to the hole. That is the confusing part. Thanks agian.
Old 06-15-2005, 05:20 PM   #13
67ChevyRedneck
Yes, you use a coil bolt to hold it down.
Jesse James
Project "On a Dime"
Old 06-16-2005, 01:53 PM   #14
shifty
Questionable
shifty's Avatar
There are four bolts to attach all four the corners of the coil. In the instructions for the coil when you buy it, they typically say to take the black wire coming out of the coil and bolt it to the corner. In this case, I bolted the black wire to the (as you look at it) the front left corner. Then I ran a grounding strap manually from the ground tab between where the red and yellow wires connect over to the front right corner (opposte side from the other black wire I just described)
Old 06-16-2005, 01:54 PM   #15
shifty
Questionable
shifty's Avatar
I can snap another photo tonight if you need it. I need to finish the second coat of header paint on my headers, scan an article for a couple of guys here and shoot some other photos. I should be able to squeeze it all in.
Old 06-16-2005, 02:17 PM   #16
tomatocity
tomatocity's Avatar
Thank you. I think the photos and documentation will be helpful to many of the members over the course of time.
