Old 06-15-2005, 03:31 PM   #1
Purs
Got Big Block?
Purs's Avatar
radiator cover
What is everyone using for a radiator cover? I'm not looking for chrome, maybe polished aluminum or black powder coated. Surely someone makes an aftermarket one.
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 06-15-2005, 03:57 PM   #2
71Dragtruck
71Dragtruck's Avatar
Not sure about the cover, but I suggest brackets to mount your fans. Fans are heavy and vibrate, with through mounts you will end up wrecking your rad over time. Ask Wes what happened to his new 4-core when he used them.
71Dragtruck is offline   Reply With Quote
Old 06-15-2005, 04:32 PM   #3
Purs
Got Big Block?
Purs's Avatar
71Dragtruck, I agree. Brackets would be better. I previously had my fans mounted this way on my chevelle for some time without any problems though. I'll probably end up fabbing a nice aluminum shroud for both of them once I get everything together and running.
Old 06-15-2005, 04:53 PM   #4
john
member #16
john's Avatar
look here
http://www.classicheartbeat.com/
Not polished but looks pretty good. John
john is offline   Reply With Quote
Old 06-15-2005, 04:57 PM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Alot of the BOARD VENDORS carry the one like LMC has,
their price is $29.95 paintable, and $49.95 Stainless, Any
of the board vendors can get em, probably cheaper.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 06-16-2005, 12:10 AM   #6
kelsfine69
18 Till I Die
kelsfine69's Avatar
I just made a brushed aluminum cover that is held on by the rad supports. If your looking for a bigger one that covers the rad support and the rad I suggest try your local metal/tin shop. It would be very easy to make and take only 10-20 min.
PS
where did you get the brass fittings for the waterpump bypass hose
kelsfine69 is offline   Reply With Quote
