Old 06-19-2002, 09:46 AM   #1
Zumo
Hot Rods For Life
Zumo's Avatar
Where these factory options
Is this A/C? Was it a dealer installed option?
Are these still available and do they work well? This pic is out of a Burb I saw on Autotrader.
1968 C10 LWB ****SOLD***
Andy
Viva Los Bicicletas!
Los Muertos Custom Bicycles
Zumo is offline   Reply With Quote
Old 06-19-2002, 09:53 AM   #2
cacauba
STL-KKN
cacauba's Avatar
don't look like mine, mine is factory. i think that it's aftermarket
1969 C10 350/POWERGLIDE
1991 1500 EXTCAB 350
Formally: collegeK5er
cacauba is offline   Reply With Quote
Old 06-19-2002, 10:13 AM   #3
Low69CST
I've seen those before. Its definately add-on air, or aftermarket. Its definately not GM. I think it was sears my dad was telling me use to install lots of add on A/C units on cars years ago.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 06-19-2002, 10:23 AM   #4
fishuntr
I don't know the answer to your question, but my air on my 72 is identical. My truck was bought new in Ontario, CA. The original owner had the air added on; whether through the dealer, Sears, or somewhere else, i don't know. Unfortunately my old huntin buddy passed away a few years ago.
72 C-20,LB,350, 4spd, 1 owner
fishuntr is offline   Reply With Quote
Old 06-20-2002, 09:52 AM   #5
Zumo
Hot Rods For Life
Zumo's Avatar
Anyone else have this type of setup?
Andy
Old 06-20-2002, 10:44 AM   #6
ckhd
ckhd's Avatar
Underdash air is fairly common. There were both dealer installed units (should have a GM logo somewhere on the unit) and aftermarket units.
As far as I know, there are not any "Factory" under dash units. "Factory" air-conditioning is the vents in the dash. The ones that are referred to as a factory under dash unit are typically the GM dealer-installed units.
Hope that helps.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 06-20-2002, 10:46 AM   #7
ckhd
ckhd's Avatar
Oh, I do believe you can still get them. You can also get (for close to the same price, I think) a kit that will get you the vents in the dash - with some dash cutting involved. I'd go with that route because then your passenger won't be kicking the unit, and it looks a lot 'cleaner'.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Old 06-20-2002, 10:50 AM   #8
ckhd
ckhd's Avatar
Try these guys www.vintageair.com. They have both under dash "universal" styles, and the kits to make it look factory (in the dash vents).
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Old 06-20-2002, 11:50 AM   #9
nroden
nroden's Avatar
I have seen (may have been in 72 owners manual these). They were a GM dealer add-on. They also have an AC setup that sat on top of Burbs (and possibly blazers)
Nick Rodenberg
72 Cheyenne 10 V8 350/TH350
white/ochre/white/ochre, ochre/saddle interior
Retired and in the dry... still runs. I now drive Red '01 Ford Focus... better MPG!!!
nroden is offline   Reply With Quote
