06-15-2005, 05:41 PM | #1 |
91 ignition problem
i know i am new here but i hope you guys could help me out. my 91 suburban was starting to miss a little bit so i decided it was time for a tune up. so i put new wires, plugs, rotor and cap on. now i have no spark at all. i then put a new control module on and then a new coil. i still have no spark. what should i do next. the engine is a 350. any suggestions would greatly be appreciated.
06-15-2005, 08:30 PM | #2 |
Tonawanda 454
are you sure it is missing spark? have you checked to make sure it is getting gas in the TBI? it might be something as simple as a loose 12V wire or ground going to the distributor or the coil..
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!! 04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011) In the past 30 years about 90% of Fords are still on the road, the other 10% made it home. ------------------- |
06-23-2005, 10:47 PM | #3 |
thanks screwball i will check that next appreciate it
06-24-2005, 09:47 AM | #4 |
Tonawanda 454
also our burbs were known to have a "wear spot" on the distributor assembly just above the gear... it is best to replace the whole assembly if this is the case...
06-24-2005, 05:11 PM | #5 | |
