Old 06-15-2005, 08:36 PM   #1
tomatocity
tomatocity's Avatar
C20 to C10, How To
I can't figure out how to search for a How To or FAQ so I am forced to ask a question that many of you have heard many times before.
I am looking at a couple of C20's. If I were to buy one I would eventually like to convert it to a C10 for better looking wheels and ride quality. What parts need to be changed to make a C10? Do C20's have rear coil or leaf springs? Thanks in advance.
To answer a future question(s). Some of the C20's for sale are better equipped, in better condition, and better priced than the C10's.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 06-15-2005, 09:19 PM   #2
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Don't you mean they are easier to find?
Edit: OK, I admit it. I was looking into this as well. Could not swing the dollars though. ECE sells conversion spindles and axles so you can swap wheels. You keep the suspension. http://www.earlyclassic.com/catalog....ry=New%20Items
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 06-16-2005, 06:18 AM   #3
There are endless wheels available in 8-lug.The brakes are bigger and that`s good if you`re going the hp route.Bigger brakes are better for tall wheels,too(the origins of the current tire/wheel trend.Race cars needed larger diameter wheels to clear big brakes).Just a thought.
Old 06-16-2005, 09:10 AM   #4
jtminton
II Timothy 4:2
jtminton's Avatar
My C-20 has a coil rear.
72 C-20 2WD LWB Custom Camper Deluxe 350 4 Speed "Project Lazarus"
MY TRUE PRIDE AND JOY
"Dangit, Bobby, people will see that oil stain and think I'm a drunk."
jtminton is offline   Reply With Quote
Old 06-16-2005, 03:59 PM   #5
chickenwing
Tim, it is Tim, isn't it? Check out todays bee. 2 4x's in the 4x section and 3 or 4 shortbeds in the classics section.
edit: There is even a 72 blazer in the sport/ute section for $1500.
Old 06-16-2005, 05:32 PM   #6
Maximum Overdrive
December 21, 2012
C20's come in both leaf spring and coil spring set up. You would need to change out the entire rear end and possible springs for a softer ride and I would think as to the front end you could get away with using 1/2 ton ball joints and drums and using the existing A arms on the C20, not sure though.
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
Old 06-17-2005, 04:18 AM   #7
rwgregory
From what I have seen, GMC's have leafs & Chevy's have coils, unless it's a 4x4, in
which case it would have leafs as well. Also, I agree with "special-K". Bigger brakes,
larger radiators(good for big-inch motors), tranny coolers etc. I really think too many
people overlook 3/4 tons when looking to build trick truck.
that's my opinion.....
rwgregory
rwgregory
67 GMC 2500 ,2w/d wide box
305 V-6, 4-speed
rwgregory is offline   Reply With Quote
