Old 06-15-2005, 09:30 PM   #1
mocwon
Keep On Truckin'
mocwon's Avatar
Question Rear end drain plug
Anyone drill and tap the differential (12 bolt) for a drain plug? If so, what size and location? Thanks
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 06-15-2005, 11:51 PM   #2
mjrmn
'67 K10 Work In Process
mjrmn's Avatar
Most diff drains I have seen are in the cover. They usually consist of a fitting that goes thru a hole you drill in the cover which has internal threads for the plug and seals on each side to prevent leaks. You should be able to buy a drain plug kit from an area auto parts store. Not the best description but I hope this helps.
mjrmn is offline   Reply With Quote
Old 06-16-2005, 01:49 AM   #3
71Dragtruck
71Dragtruck's Avatar
Ya just put it on the cover, you can get a kit like mjrmn said, or weld on a threaded collor, drill a hole in it, and install a plug. If you feel like spending money LPW's Ultimate-12 cover has a fill and a drain.
71Dragtruck is offline   Reply With Quote
Old 06-16-2005, 06:59 AM   #4
mocwon
Keep On Truckin'
mocwon's Avatar
Thanks!
Just Passin' Thru
Old 06-16-2005, 11:13 AM   #5
junkyardjohn
junkyardjohn's Avatar
I JUST BOUGHT A NEW CHROME ONE AT NAPA WITH THE DRAIN PLUG ALREADY IN PLACE. SEEMS LIKE IT WAS $22 JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
