06-15-2005, 10:47 PM | #1 |
Questions on putting a 2wd body on a 4x4 chassis
so i bought a 67 c10 and a 71 k10. the 67 has an excellent body with no rust while the 71 has a beat up body. so im swapping bodies. I have heard that there is a larger hump in a 4x4 cab....so if i'm putting a 2wd cab on a a 4x4 chassis will i need to get a body lift?
if i get a 2" body lift...then will the front and rear bumper still be 2" lower? if so how do i fix this or do i even need to fix this? are there any other problems that i'm going to run into that i need a headsup on?
67 4WD c10, lwb, 350-v8 71 2WD k10, lwb, 292-l6 in pieces |
06-15-2005, 10:58 PM | #2 |
The hump in the cab unbolts....so you could replace it with the hump out of your 4x4.
BTW Welcome to the board....this is great place!! Last edited by 402Bowtie; 06-15-2005 at 10:59 PM. |
06-15-2005, 11:18 PM | #3 | |
Where's my beer?
Welcome! this place is a great resource of knowkledge.
Paul How do you make the invisible, visible?.........You take it away. |
06-15-2005, 11:45 PM | #4 |
The hump in the 4X4 unbolts. You make a pattern and cut out the 2wd tunnel so you can bolt the high hump in. I'd put the 67 body on the 71 frame so you already have front disc brakes. That should be a nice truck when done, we sure need pics!
06-16-2005, 01:13 AM | #5 |
Thanks for the help
06-16-2005, 02:44 AM | #6 | |
'68 C-20 396 CST CC
Check this...if both cabs have an uboltable interface you are home free. No lift needed. The small hump is formed like a car...you could spot the difference immediately. Good luck on this swap Jman, I've done a couple three of these. You will need to use the 4x4 speedo cable and hopefully the 71 has disc brakes. You'll have to post more information about the transmission configuration and what the end config will be to get things together...
68 C-20 396/TH400 CST Custom Camper NOW W/DISC BRAKES 01 Jetta Turbo Daily Driver 84 Yamaha Virago 700 - Alaska to Florida Via Maine & Mexico |
06-16-2005, 05:45 AM | #7 |
Welcome to this site.If your `67 is a 3spd or automatic and you need to buy a high tunnel,Teeitup is selling them in the parts section,now.I don`t think a body-lift is a good way to go,IMO.The bumpers won`t line up with the body and you`ll have a rigid mount.Modifying the floor is the "factory-like" way to go.Let`s see pictures if you can,both trucks.Is the`67 a small wimdow?Most were.Is the`71 cab banged-up?If not,you could retain just the cab,keep the original VIN-plate,and have the high tunnel.
06-16-2005, 06:41 AM | #8 |
Yeah, to state the obvious, once you resolve the hump controversy, no need for a body lift that would just complicate matters. Replace the body bushings during the swap to get good leveling of the body on the frame.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
06-16-2005, 09:59 AM | #9 |
if it is an auto or three speed the low hump is fine, you only need to cut a hole for the t-case shifter( obviously ). the only reason for the high hump is if you have a top loader 4 speed....when i built mine i used a 2wd cab and changed the hump, and then when i got it together w/my 3 speed i realized i didn't have to ... good luck lets see pic's...welcome, John
71 chevy 4x4 ,np205 transfer case, 3 speed tranny, sjs 283, 4in suspension lift, and 71 hugger orange paint,33x12.5 parnelli jones on 15x10 m/t classicII, cowl hood,new bed painted, linex liner. Truck has been completed since 2005.... 2003 Chevy Avalanche Z71, on 6in super lift w/ 35in tires RNG4x4 aka the "Redneck Roller" words to live by "If it fits, it fits" "friends help you move, real friends help you move bodies..." Sponsored by "Kick Ass Kustom" |
