Old 06-15-2005, 11:27 PM   #1
Gramp'sGold70K20
New
Gramp'sGold70K20's Avatar
Question Another HEI Question
PLEASE HELP!!
I just can't figure this one out. I have a brand new battery, alternator, and MSD HEI (Model 8365) that I installed in March. I was driving to work and the truck just died as if I turned the ignition off. The first thing I replace was the coil. It started right up and I thought the problem was solved. After about fifteen minutes at idle, the truck just died. No spark going to the plugs. I waited about 2 hours (because I was frustrated) and started her up again. The same thing happened after about 5 minutes. It seems that as soon as the engine warms up, I loose the ignition. Do I have a bad circuit board in the distributor? I don't know what else to check. Any suggestions? I am thinking about taking this model back to the dealer and replacing it with model 8360. The 8365 was a little too big and came real close to the firewall. I think I like the looks of the smaller unit with the coil mounted on the side anyway.
Signed,
Gramp'sGold70K20 is offline   Reply With Quote
Old 06-16-2005, 12:03 AM   #2
68haywagon
I'm watching you!
Did you replace the original wire from the firewall to the distributer? I know the original cuts down voltage after the truck is started to preserve points on a points ignition. I replaced mine with 12g wire.
Dunno if this helps.
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 06-16-2005, 12:26 AM   #3
Gramp'sGold70K20
New
I will replace it in the morning. Looked at the FAQ thread on HEI too. I will follow the schematic posted. Thanks for the input. I hope that is the problem. Why would the problem creep up now rather then when I installed it a few months ago? I will let you know if this cured it. Is there anything else I may have overlooked?
Old 06-16-2005, 12:43 AM   #4
boraxman
Keepin an eye out
boraxman's Avatar
Module? However I think when they go they go.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 06-16-2005, 09:37 AM   #5
72K10
Sounds like the ignition module. They sometimes go slow, sometimes drop dead. The ones that went out on me went slow, much like what you're describing. I think they run around $25 and are pretty easy to replace.
RLTW
70C10
72K10
72K10 Cheyenne
72C10 Cheyenne Super
72K10 is offline   Reply With Quote
Old 06-16-2005, 10:59 AM   #6
junkyardjohn
junkyardjohn's Avatar
WHEN YOU INSTALLED IT A FEW MONTHS AGO EVERYTHING (CAP,ROTOR, PLUGS, WIRES, ALT. ECT. ECT.) WAS BRAND NEW & WORKING AT 100 % . NOW A COUPLE OF MONTHS LATER, EVERYTHING IS WORN A LITTLE & THE VOLTAGE DROP IS QUITE NOTICABLE. THE ORIGINAL WIRE HAS A RESISTER IN-LINE, DROPPING THE VOLTAGE TO ABOUT 9 VOLTS. MAYBE THIS ISN'T YOUR PROBLEM AT ALL, BUT IT'S THE FIRST THING I'D CHECK. EVERY MODUAL THAT I'VE EVER HAD GO OUT ON ME, JUST COMPLETELY & PERMANATLY QUIT. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 06-16-2005, 01:02 PM   #7
GlennBrittain
I had exactly the same problem. Installed a new MSD Pro Billet dist. ran fine for two months then would not start. I had 12v on the orininal wire, the white one, and 9 volts when turning the starter over. After changing out the dist. I found the white wire melted under a tape wrapped around multiple wires. One stand was still making continuity allowing for the voltage bu not enough amp's. I repaired the white wire, same thing happened again. I ran the 12g wire to a ingnition connection on the fuse block, problem solved. I also put in a inline fuse.
GlennBrittain is offline   Reply With Quote
Old 06-16-2005, 05:38 PM   #8
Gramp'sGold70K20
New
I insalled the new 12g wire with the inline fuse into my spare ignition slot on the fuse panel. Fired right up and stayed running!!! You people are great!! I don't know what I would have done without this board. Thank you everyone!
Old 06-16-2005, 05:41 PM   #9
68haywagon
I'm watching you!
I'm glad it worked out.
Mike
Old 06-16-2005, 05:46 PM   #10
junkyardjohn
Hey Gramps.... Glad You Got Your Truck Running Right. I Went To High School In South Lyon, & Before That I Lived In Plymouth.(The Next Small Town In MI.) This Was Along Time Ago. I Graduated In 1976. Small World. John
junkyardjohn
DON'T RENT U-HAUL
Old 06-16-2005, 05:55 PM   #11
GMC AMI
GMC AMI's Avatar
Thumbs up
Originally Posted by junkyardjohn
Hey Gramps.... Glad You Got Your Truck Running Right. I Went To High School In South Lyon, & Before That I Lived In Plymouth. This Was Along Time Ago. I Graduated In 1976. Small World. John
1976 was a good year to leave school!
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 06-16-2005, 09:40 PM   #12
Gramp'sGold70K20
New
Thanks again everyone!! It's good to be driving again instead of being stuck on the side of the road!
