![]() Join Date: May 2005
dash speaker vents?
is there anybody out there that can tell me why some 69-72 blazers have the speaker in the dash pionted up through the speaker grille like a truck and some have the speaker hanging from the heater/ac control screws under the dash pointed towards the rear of the vehicle with no speaker grille in the dash? the top of dash is smooth. why? i tried to figure it being the year, gmc or chevy, or maybe even the different plants they were built in, but came up just as clueless as before.
67 short fleet 71 blazer 4x4 72 blazer 2wd 76 gmc sierra 3/4t 4x4 62 bel air 01 blazer extreme member 11,943! |
I think you have just as much of a clue as anyone else does.
Can't remember where I read this: AM radio got the under dash speaker, upgrades got the truck type speaker????
I have a Blazer windsheild frame that had an AM and it has the grille in the dash.
The story I heard was that they moved the speaker below in '71 because of the water damage with the top off on the Blazers... then went back to the dash location to simplify production. Whatever the case, It seems to be a real hit and miss. I've always wondered if there was any correlation to having the speaker in the dash if it was equipped with A/C...
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod |
![]() Join Date: Jun 2002
Both my 69 blazer and 70 jimmy are minus the speaker holes. But they both also came with the radio delete plates on them also... It is a mystery fer sure...
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
Check out GMTrucks.org
The A/C is an interesting thought. Mine is a 72 with A/C and the speaker is mounted below. Anyone with A/C with the speaker in the dash?
JB-80 "Twice as Good"
.......both my 69 and 72 are below the dash, the 72 has A/C the 69 does not. I bet GM snuck a few pickup dashes into the mix!
HEY NOW! |
Member since 2000
My 70 blazer doesn't have the truck style speaker hole. It did have a radio though, When i bought it the owner took it out to drop it in his own blazer.
70 Blazer with A/C = solid dash
71 Blazer with A/C = solid dash 70 pickup with A/C = speaker grill... ![]() |
Member since 2000
Do you guys think the speaker thing is based on what factory the Blazer was built at?
![]() Join Date: Apr 2000
i read that they used truck dashes in some blazers, guess just to use up some year end parts.
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
#13 |
computer illiterate
my 72 2wd 1 owner has ac and an am radio with the grill in the dash
72 2wd blazer 72 swb 4x4 |
#14 |
Big Block
No speaker grills
I have two 72 CST Blazers. The 4x4 was built at St.Louis Mo. plant, Factory AM radio no A/C and no speaker grill. The 2WD was built at Flint Mi. plant had factory AM/FM with A/C no speaker grill. I also have owned a 71 GMC Jimmy 2WD had factory AM radio A/C and no speaker grill. It was sold to a friend a couple of years ago. I would like to have that one back! I'm sure the grills were removed to prevent water damage to the speakers when the top was remove. Remember the top was an option. But I would bet if they ran out of blazer dashes on the production line you would end up with a truck dash. B.B.
#15 |
Sounds like the only correlation is that nothing correlates!
#16 |
In previous discussions on this, it seems like only some '72s got the "truck" dashes with the speaker holes. I think this was because they just used the parts they had on hand as they ran out the last of the production on this body style.
Tim |
#17 |
72 Jimmy, A.C, AM Radio, speaker in dash, built in Flint.
#18 |
72 Blazer CST "Highlander" - Has air - had speaker mounted above radio, but no speaker grille. I was wondering about this. How does the speaker sound without a grille in the dash? The speaker was never connected since I've owned it.
Jeremy (NUBOMB) 72K5 CST 350/350/205 1951 Chevy 1/2 ton North Georgia Group "... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman. Last edited by NuBomb; 06-18-2005 at 11:44 PM. |
#19 |
![]() ![]() Join Date: Jan 2002
Did a truck with a radio delete plate come with a grill in the dash for a speak. I have 70 jimmy and it has no grill in the dash and came with a AM radio
#20 |
![]() Join Date: May 2001
I have a 72 with A/C and a factory AM radio and NO grill on the top of the dash.
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
