Old 06-16-2005, 05:23 AM   #1
Clos'84TX
Foom, foom, foom!
Clos'84TX's Avatar
Transmission advise th350
I need some advise about a leaky TH350, I have changed pan gaskets, tranny pan, and o ring on my dipstick tube. And still have a tranny leak, it is coming from the passenger side front corner of the tranny. All I could think of was the kick down cable, which I changed out a little while back....is there some type of gasket or some thing I can put between the cable housing and the tranny housing....
Or has anyone else ever encountered this dumb problem..please give me some advise.
- Dan
84' LWB C10 // 2.5" from collector back. duel Turbo
Mufflers // 350 w/ TH350
long Headers//3.73 rearend gears
Future Mods
3/4 suspension drop
Clos'84TX is offline   Reply With Quote
Old 06-16-2005, 08:02 AM   #2
76bonanza
76bonanza's Avatar
Mine drips from the passenger side front but that is the way they tilt when mounted mine is slowly leaking from the front pump seal but only drips fro the passenger side front? Just a thought
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 06-16-2005, 09:36 AM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
The kickdown cable on my '86 TH350c uses a rubber gasket where the cable goes into the transmission. Mine was leaking, and the replacement part stopped that leak. The part is a little piece of rubber, shaped sort of like a thimble with a hole in the end. I bought it at O'Reilly Auto parts for less than $1.
At one time I thought my pan gasket was leaking. It LOOKED like it was the pan gasket. I replaced it a couple of times before taking it to a friend who is a mechanic. He discovered the pump was leaking, and running down onto the pan.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 06-16-2005, 03:20 PM   #4
crawdad
crawdad's Avatar
I just replaced the o-ring on the filler tube of my TH350. A few days later it was leaking again. Come to find out, it was the tube itself. It had a small hairline crack in it near the base where it goes into the transmission. Replaced that and that cured my leak problem. Might be worth a look anyway.
2012 Silverado LT 1500, 5.3, 6 speed auto
'86 SWB C-10 Silverado
crawdad is offline   Reply With Quote
Old 06-16-2005, 05:11 PM   #5
Slonaker
Slonaker's Avatar
That's the kind of stuff that drives me crazy. Everything that goes wrong with my truck always seems to be something weird that no one has ever heard of.
Slonaker
Stock '01 Silverado
Old 06-16-2005, 10:04 PM   #6
crawdad
crawdad's Avatar
Slonaker
I know exactly what you mean. I was just about ready to tackle replacing the window motor on my passenger side door. This afternoon, I hit the switch and, low and behold, it starts working again. In fact, it's working better than the driver side window, and there was nothing wrong with it. My next major job is to try and clean up all of the cut and loose dangling wires that was left by my nephew and his friends when they replaced the motor. I don't have a clue what they go to, but there sure are a lot of loose unattached wires in my engine compartment. Maybe if I wait long enough, they'll do like the door window switch and just hook themselves up and start working again.
Old 06-16-2005, 10:17 PM   #7
Slonaker
Slonaker's Avatar
Maybe you'll get lucky. If you don't, start a thread and post pics of the wires. I have the same truck as you, and have spent way too much time messing with those same wires. If I can't identify them someone here will.
Slonaker
Stock '01 Silverado
Old 06-16-2005, 10:46 PM   #8
crawdad
crawdad's Avatar
Great idea. I'll do that.
Old 06-17-2005, 03:13 AM   #9
Clos'84TX
Foom, foom, foom!
Clos'84TX's Avatar
Slonaker
, I'll be doing that this weekend, maybe I'll be able to park in my driveway after this all.
PS getting my differential gears changed ove this weekend. Along with a chrome cover...
- Dan
Future Mods
3/4 suspension drop
Old 07-12-2005, 08:51 AM   #10
Clos'84TX
Foom, foom, foom!
Clos'84TX's Avatar
Just an update. I changed out my dipstick for a flexible braided one..Nice.
But lo and behold the love of my life...I hate this leaky thing...I've tryed different gaskets and o-rings? Advise?
- Dan
Future Mods
3/4 suspension drop
Old 07-13-2005, 10:26 AM   #11
86 GMG
have you checked all gasket surfaces for abrasions that may be cutting the new gaskets you have installed i believe you said you have change the pan also if not check that for bends on the lip or scuffs or scatches that can cut the gasket best of luck on your repairs
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
