Old 06-16-2005, 05:43 PM   #1
hickey6
69 Chevy Truck Front Brakes
Can anyone guide me through the least costly process of replacing my front drum brakes with power disc. WHere do I buy them and what are my options for the least amount of $$
hickey6 is offline   Reply With Quote
Old 06-16-2005, 05:44 PM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
http://www.crussenclassics.com/catalog.htm
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 06-16-2005, 06:18 PM   #3
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Find a 73-up truck with power front disks and swap the cross member and other needed parts. I'm getting my set-up out of a 73 burb in exchange for hauling it away and stripping the good parts off so he can sell them. Not gonna cost me a dime, 'cept may be for a quart of brake fluid.
'69 Chevy 3/4 ton, 327cid, Carter AFB, Edelbrock intake, HEI, TH400.
Founding member of the No Money To Spend On My Truck Club.
When your at Home Depot, you WISH you had gotten an 8 foot bed!
Cat Fuzz is offline   Reply With Quote
Old 06-16-2005, 06:55 PM   #4
Hart_Rod
Hart_Rod's Avatar
PM Sent. Check out this link:
http://67-72chevytrucks.com/vboard/s....php3?t=156778
Hart_Rod is offline   Reply With Quote
Old 06-16-2005, 11:32 PM   #5
4tiresngas
An American Soldier
4tiresngas's Avatar
I swapped out mine on my '69. I bought dropped spindles from Early Classic Enterprise, but you can get stock height if you want. They are machines to accept the tie-rods and ball joints from a '69. So, you don't have to remember what year every part came off of later on. I just went down and bought new rotors, bearings, calibers, and pads for a '73 from AutoZone. The brake lines, I bought from InLine Tube. Now, they were not that cheap...but they are stainlees steel with steel braided hoses. I have to say they went on really easy, so I guess they were worth the money.
Dan
dan.brue@us.army.mil
4tiresngas is offline   Reply With Quote
Old 06-17-2005, 12:14 AM   #6
Mongo
YES_____NO
Mongo's Avatar
IT is not nessary to change out the crossmember. all you need is the 73-up
upper and lower control arms (with spindles still attached). They bolt up and it is hell a lot easier to change without a lot of headache of messing with the crossmember.
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown
Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984
Help support the board
Mongo is offline   Reply With Quote
