67-72 Addict!
I just bought a Grant 440 wheel and according to the box I need a 3163 installation kit. On the box it says up to 1969 uses a 3162 kit. My column is a stick column. I have no idea if it's original or not. I thought all the stick columns for our trucks were the same. I haven't installed it yet so if anybody has this setup and could shed some light on this, I would appreciate it. Thanks
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
I have a Grant GT steering wheel in mine and it's a 3 speed manual column. I used the 3162 kit and it worked great. Took about 1 hour from start to finish.
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
![]() Join Date: Jan 2001
Location: Katy, TX...but the love of my life resides in Dublin,OH.
I used a 3163 for mine. 71 auto column. I work for O'reilly's part time in the evenings (to get a discount on parts...hehe) and the catalog didnt specify anything for standard or automatic. I can double check tonight.
Thats just prime!
I had one of them grant steering wheels that i got off a 72 gmc truck in the junkyard. Easy, very easy swap exept for two things.
1. the wheel was too d_m_ small, i think it was a 12 inch but it looked good in the cab of the other truck probably because it had no seat in it. duh 2. Another "Duh" because whenever i turned it it would grind with the column, cause the dude hit a pole the wrecked gmc and his body probably hit and bent the wheel. In all it was a cool wheel (too small) so now it is used to decorate the garage on the wall.
*69 GMC short bed stepside with a wimpy six that can barely pull itself. *99 Chevrolet Camaro Z-28 1 Bad 5.7ltr LS1 |
67-72 Addict!
Thanks guys,
I'll just go with the box recommendation. The reason I bought it was my late model Chevy truck wheel is too big in my opinion.
Currently Blazerless
I've had several grant wheels and really liked the looks and feel they give, I just wish they could come up with a better horn button, they've used the same cheesy setup for years.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
1960-1969 use a grant 3162
1970-1973 use 3163 1974-1994 use 3196 catalog offered nothing about standard or automatic columns except for 1976-1981 Vans they are different |
