06-16-2005, 06:42 PM | #1 |
Speedwarning - picture of buzzer and harness mounting?
Where does the buzzer for speed warning mount? Where does the harness hook up to the gauges?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
06-16-2005, 09:50 PM | #2 |
sean, i took a pic of mine with the wire attached to the metal housing, the buzzer is screwed in the the back of the dash right behind the cluster, and the orange wire is a hot.. hope this helps.
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
06-16-2005, 10:30 PM | #3 |
There is a stud on the back of speedwarning dashes where the wiring harness connects to..the other end goes to firewall fuse panel and the connector get the buzzer on the other end.
Solver posted this pic of where his was at...there in about the same area on most..there in that general area. One that I found myself was on the other side of steering column at same height on inner firewall. And you can see the stud by the left arrow. .
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
06-16-2005, 11:37 PM | #4 |
Jamie and Rod, thanks for the help!
06-17-2005, 12:08 AM | #5 |
YES_____NO
Hmm I usually wait for the red and blue warning light in the mirror to tell me if I am over seed, no need for buzzers.
Seriously, how does one of them speed warring buzzers work anyway? Are they pre-set to a certain speed or can you set them to any desired speed?
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984 Help support the board Last edited by Mongo; 06-17-2005 at 02:05 AM. |
06-17-2005, 11:06 AM | #6 |
There is a white needle that you set at the speed that you want. There is a small knob next to the wiper/lights on the left.
