Old 06-16-2005, 07:55 PM   #1
SSC's76
No No
SSC's76's Avatar
Question Driveshaft clock or no?
Changed my U-joints toady, dident bother to mark the shaft as far as I know it doesent need to be clocked in any certain posistion. I ask because there is a slight bit of vibration now that wasent noticeable even with the two screwed up U-joints.
Edit: This is the 100000000 time its been out so I couldent have been lucky every time but now right? BTW U-Joints went in nice no binding whatsoever.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 06-16-2005, 08:07 PM   #2
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Arrow
You should always do it if you can cuz the shaft has small balance weights spot welded to it and its balanced in that position.
But since you r&r the u joints and there not exactlly mfg. to close tollerances as far as weight go's so it may not matter anyways if you did clock it .
You may have to take it to a drive line shop for ballancing.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 06-16-2005, 10:48 PM   #3
1FaastC10
1FaastC10's Avatar
u joints shouldnt make that much of a difference in the weight. my guess would be that your rear joint is favoring one side of the yoke more than the other. while it wont bind like that, it will definitely give you a vibration. get it checked out ASAP, because an imbalanced driveshaft will eat your pinion bearings in a very short time.
1FaastC10 is offline   Reply With Quote
Old 06-16-2005, 11:13 PM   #4
SSC's76
No No
SSC's76's Avatar
I re-checked it an hour ago, everything is set in correctly swaped the yoke around, dident make any difference. Checked for excessive heat too since that would be an indicator or side load or a faulty/damaged roller bearing, nothing found. I've actually been debating to spend the $80 to have the DS ballanced but Ive been holding off in hopes of finding an aluminum replacment.
Old 06-17-2005, 07:52 PM   #5
Tom
driving is in my blood
Tom's Avatar
I don't get it. Its balanced to spin, not to sit in one spacific spot. And the position of the shaft is constantly spinning on the machine which dosen't use the rear end or the tranny to help balance, so why would the position of the weight matter at all? As long as the weight itself isen't moved on the shaft then it shouldn't matter one little bit which position the shaft is put back in...
Old 06-17-2005, 09:20 PM   #6
87 STEPPER
87 STEPPER's Avatar
Arrow
What you say sounds good!
But the factory GM maintenance manual tells you to mark/clock the position of it when it is removed so it can be put back in the original positoin.
It probably wouldn't matter any ways as old of a truck that he has who knows how many times its been removed and replaced.
Im lucky i bought my truck new and i clocked it with a center punch so i'll never have a problem knowing what way it need to be weather it makes a differance or not.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
Old 06-18-2005, 02:25 PM   #7
SSC's76
No No
SSC's76's Avatar
Yea, my truck was bought new too, too bad it was a couple years before I was born.
Anyway it happened, drove out to the county to help my brother drove back into town went back to the county then was heading home. 70MPH BHHHHHHHHHRRRRRWHHHAAAAAAAAAAAAAAATTTTTTTTTTTT. The front u joint snaped in half!!! It's still in the yoke in sevral peices must have had a hairline crack that would expand under load to cause the vibe. Now my truck is stuck 8 miles away. At least I made it to the motorsports park entrance where I shouldent get a ticket. I just hope nothing got too chewed up or it will be tuesday before I'm able to get another DS.
Old 06-20-2005, 01:47 PM   #8
KShortell
KShortell's Avatar
Originally Posted by SSC's76
1976 C10 SWB Med FMB
You can't get it wrong on a 2WD driveshaft. GM keyed the slip yokes to only go on one way. The 4WD driveshafts didn't have this and you do have to pay attention in that case.
But, since you've got a 4x2, I'd have to say to start looking elsewhere than the U-joints.
Good luck!
Semper Paratus
KShortell is offline   Reply With Quote
Old 06-20-2005, 02:40 PM   #9
SSC's76
No No
SSC's76's Avatar
Good luck!
Yea but if you read the post above it was the u-joint, it snaped in two.
I was able to fix it sat night. I took the driveshaft out ran it to the shop put another U-joint in went back and got it going. I ran it up to 4k in 3rd a tad over 100 with no vibration at all now.
To give an idea of how bad it was vibrating all the header bolts came loose. I've never had to tighten these ARP bolts since they were installed 3 years ago until this happened.
