06-16-2005, 10:21 PM | #1 |
87 Suburban need help
Someone told me if I take the fuel lines off at the throttle body and turn the key that gas should come out of them. Is this true, because mine isn't doing that and I need to get this thing running. 87 Suburban half ton 350 4wd.
06-18-2005, 04:19 AM | #2 |
Truckless for the moment...
Yes, it's true. Could be a bad fuel pump, or wiring going to it.
1987 V1500 GMC Suburban, 350 TBI, Flowtech dual exhaust, Rough Country 2" spring lift, 56" 3/4 ton rear spring conversion, 33" BFG All Terrains, and the smokescreen engine mod -- Former truck, searching for another now... |
06-18-2005, 09:40 PM | #3 |
Welcome to the board from western n.c. If you take a hammer and (smack) your tank and it will start,fuel pump...The fuel pump relay is under the hood ,bolted to the fire wall..and there is a in line fuse near it too...Try these 3 things...it has to be simple...And could be a lost ground or broken wire near the tank too..Common Hope this helps,Erick
Bob there is a great one when it comes to burbs too... |
06-18-2005, 11:53 PM | #4 |
thanks, i will check it all
06-19-2005, 06:35 PM | #5 |
Does anyone know where fuel pump fuse is? Fuel pump Relay? I can't find it. On 93 Suburban it is bolted to the firewall on the left. But in the 87 nothing is their and i can't find it.
06-19-2005, 07:23 PM | #6 |
nevermind found it
88 Gmc Sierra 1 Ton 4x4 454 7.4Lt. 87 Chevy Suburban 1/2 Ton 4x4 350 5.7 Lt. 93 Chevy Suburban 1/2 Ton 4x4 350 5.7 Lt. |
06-19-2005, 07:28 PM | #7 |
I know you can do it!!!
