fuel pump spacer 72 chevy 350 c10
should there be a spacer between the fuel pump and the block on a 72 Chevy C10 stepside 350? I have run the casting numbers on the block and it appears to be the correct (original?) engine. This is my friend's truck and for some reason the fuel pumps last about 3 minutes and self destruct. I am wondering if the pushrod from the cam that drives the fuel pump is bent or something like that. I suggested he get a new pushrod and fuel pump. Any other ideas? Thanks very much guys!
Crosby 1978 Chevrolet K10 stepside NH |
No spacers, just the mounting plate.....
Define self destructs?
'72 C10 lwb 454/TH400 |
when installing pump does he use the bolt thru the front of the block to hold the pushrod in place while mounting the pump???
hi guys. yeah, that's what I meant, that little plate there. I don't think he has one on there. would that matter? I would expect that if it wasn't in the exact right spot, the pushrod would kill it. I don't believe he is using a bolt through the front, are you supposed to? I never have, although I have only built a few engines myself... Thanks alot!
its all about the +6 inches
Read this...
http://67-72chevytrucks.com/vboard/s....php3?t=138417 If you look in this pic, you can't run an engine without that plate. You'll drain all the oil in a matter of a few miles. |
oh yeah, I see. I was thinking that was a spacer of some type. Guess I didn't remember it correctly. Thanks very much for the help. Hope we can figure it out. Then again, if he gets frustrated and gives up, he promised I would have first crack at the truck
it seems the pump is coming apart at the diaphram, that line where the upper and lower halves meet. (the biggest round part). thanks again!
![]() Join Date: Jul 2004
Is that the correct pump for a small block ? IIRC the big block pumps have a longer arm and may bind up if used in a small block. Not sure on that, been a while, just another idea.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
