Old 06-19-2002, 02:46 PM   #1
Riptide
Steering Stabilizer
I'm thinking about putting a steering stabilizer on my 67 c10. How hard is it? Does it make that much difference? I have 32" tire and no power steering if that helps.
67 Chevy C10
McPherson, Ks
"Remember Don't Sweat the Petty Things, Pet the Sweaty Things"
Riptide is offline   Reply With Quote
Old 06-19-2002, 02:54 PM   #2
Blue68
Blue68's Avatar
Don't know about a stabilizer, but going to power steering was the best thing I ever did for keeping it on the road. At highway speeds there was a high pucker factor without power (and I had 31 inch tires at the time). After the swap, it was a whole new truck.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 06-19-2002, 02:59 PM   #3
Riptide
Yea I would love to have power steering. It 's a dream of mine... I need to find the parts for it. If you know of any please let me know.
67 Chevy C10
McPherson, Ks
Old 06-19-2002, 03:13 PM   #4
Suicide-D
Location: Katy, TX...but the love of my life resides in Dublin,OH.
I put a stabilizer on my 71. It was manual steering at the time.. it helped some. But the power setup I have now is much better. The stabilizer kit i bought was around 40 bucks and was easy to put on. I used a 71 power steering gear box, pitman arm and the pump and brackets out an 84 blazer. The pump from my 71 donor was to low and the belt was hard to tighten and got lose often...I cuss alot less now...
Suicide-D is offline   Reply With Quote
Old 06-19-2002, 03:16 PM   #5
Riptide
Will an older model chevy gearbox and pump work on a 67.
67 Chevy C10
McPherson, Ks
Old 06-19-2002, 03:22 PM   #6
Suicide-D
i dont know about the gear box but I removed the valve that the pressure hose screws into from my 71 pump and put it in the 84 pump so I could re-use my (new) hose from the original setup. I can look into the gear box tonight and get back to you.
Old 06-19-2002, 03:42 PM   #7
crew70
crew70's Avatar
power steering is the way to go!!!
crew70 is offline   Reply With Quote
Old 06-19-2002, 09:00 PM   #8
slam33
slam33's Avatar
I did the P/S convertion on my 71 and put a stabilizer on it at the same time. The stabilizer smoothes things out, adds a little bit of resistance. works great.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 06-19-2002, 09:02 PM   #9
Fast68Chevy
Fast68Chevy's Avatar
i think 67 68 4x4 p/s used manual 2wd small shaft box, and 69-up used 2wd castign with larger output shaft than 2wd, if you find a 69-79 p/s 4x4 1/2 3/4 or 1 ton thne snag the box and pitman and draglink to swap to p/s on 68 and older 4x4 1/2 to 1 ton
and just the 69-79 box and arm for swap to p/s on 69-up
67 and most 68 and older used that power assist ram piston linkage steering on p/s equipped trucks, just like 2wd did,
Fast68Chevy is offline   Reply With Quote
Old 06-19-2002, 10:59 PM   #10
68 Suburban
68 Suburban's Avatar
Riptide , I think I have a new stabilizer set up for a 2wd truck if you are interested $20 plus shipping?
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 06-19-2002, 11:13 PM   #11
Suicide-D
ok 1963 - 1974 all use the same power steering pump with variations on the reservoir
1975-1979 all use the same power steering pump with variations on the reservoir
1980-2000 all use the same power steering pump with variations on the reservoir
1968-1976 all use the same gear box
Those are all small block applications listed above big block was different
Old 06-19-2002, 11:49 PM   #12
Blue68
Blue68's Avatar
Dirt Dobber,
That information on the pumps is great. I needed to know that. Where is the information from?
http://67-72chevytrucks.com/vboard/s...threadid=16061 is another thread I asked the question you just answered on.
Old 06-20-2002, 09:29 AM   #13
Suicide-D
I have a part time gig at night at O'Reilly Auto Parts... to get a discount on parts... I looked it up in the catalog and just compared the years to the part numbers
Old 06-20-2002, 09:35 AM   #14
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
Question Hmmmmm
Okay since we are on the subject of power steering, Will a
PS gear box that was connected to a 3-speed column fit an automatic column...I'm guessing so....THANKS!!
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 06-20-2002, 09:56 AM   #15
Suicide-D
If I recall correctly the catalog didnt specify standard or automatic on the gear box. I dont think it would matter either. I didnt look up the pitman arms... I am just getting back into this auto parts thing after 4 years of doing something else and I have forgotten what items are common to each year... I'll get it back in time.
Old 06-20-2002, 02:17 PM   #16
68 Suburban
the gearbox will be the same whether it is manual or power steering.
Old 06-20-2002, 02:22 PM   #17
Riptide
What year of truck do i need to get the gearbox off of for my 67 c10?
67 Chevy C10
McPherson, Ks
