06-17-2005, 05:58 PM | #1 |
R&R A/C evaporator ........HELP???
I have to replace my evaporator on my 84 Chevy Silverado. Can I do that by just removing the right side (facing the engine) of the A/C box? Will I need a new gasket between the two halfs of the A/C box when I do that? Any idea where I can find the rubberized stuff that goes on the line outside the box?
06-17-2005, 08:34 PM | #2 |
ureckmefixit2@cox.net
Im not sure about taking just the side off. When I did mine I wanted to clean every thing out. I removed the inner fender to access the lower bolts on the A/C box. I pulled the a/c box out of the engine comp. It took about 30 min. Rebuilt A/C box on the work bench. The sealer is Strip Calking from any auto paint store or hardware store. Be sure to clean the old stuff off and put enough new calking in to seal. On some trucks they spray something like under coat over the seam at the A/C box to fire wall. Matt
That's U RECK ME FIX it 2 74 Chevy Short Bed 355ci Sportsman II 64cc Angle Plug Crower Custom Grind .462in .486ex Dyno Test 422hp @ 5600 And it's got a Holley 3.73 Gears 12 Bolt 3.73 w/Posi 700R4 Going In I'm a Body Man So There! That's why it's not painted |
06-17-2005, 09:44 PM | #3 |
thanks Ureckme..........I really appreciate the help
