Old 06-17-2005, 08:07 PM   #1
gregbr
Senoir Member
gregbr's Avatar
4WD front spring perches twisted???
I was installing a 4" lift recently and noticed my front axle front spring perches are bent or twisted outward toward the wheel. Is this OK, normal, or do I need to straighten and reinforce the frame? BTW, it's a 67 SWB factory 4wd.
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 06-17-2005, 08:38 PM   #2
jay_shy
SWB 4X4 CLUB
jay_shy's Avatar
Not sure about that. Just wondering where you got the lift kit. Does your truck have the closed knuckle front end. I have a 68 factory 4X4 I an thinking about lifting in the future.
Jason
jay_shy is offline   Reply With Quote
Old 06-17-2005, 10:55 PM   #3
gregbr
Senoir Member
gregbr's Avatar
Yes, it has the original closed knuckle front axle. I bought a Rough Country 4" softride kit for the 69-72 k10 truck. The springs/bolts/mounts are the same as our 67/68. The difference is on the axle steering arm, I could not find a replacement arm for the 67. But, with the new springs installed I have alot of movement left on the ball joint connecting to the axle arm, so it has not been a problem. But the 6" and bigger will require a offset arm, I'm sure. I removed a 4" lift (will sell soon) and installed the softride 4" hoping for a better ride. Hope this helps you, Greg
Old 06-18-2005, 06:43 PM   #4
gregbr
Senoir Member
gregbr's Avatar
ttt
Old 06-18-2005, 09:06 PM   #5
jay_shy
SWB 4X4 CLUB
jay_shy's Avatar
Thanks for the info greg. I think When its time I will get a 4 inch soft ride also.
Jason
Old 06-19-2005, 01:16 AM   #6
4x4Poet
Just to be clear, the pads on the axles that the springs set on to be u-bolt clamped to the axle are the "spring perches." The frame-mounted brackets that take a spring-eye bolt or shackle bolt are spring-eye or shackle-bolt brackets.
As a general rule, bent or twisted spring brackets are never a good thing and usually unsafe. Can you post some pics? Are both front spring-eye brackets bent or just one side? Try comparing them since they are identical in an asymmetrical sense. With all the angles and welds the brackets have, I would guess that the frame horns are bent before the brackets.
In any case, if you think they are bent, have a frame repair shop ckeck them out. Estimates should be no charge.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 06-19-2005, 03:49 AM   #7
gregbr
Senoir Member
gregbr's Avatar
OK, it's the front axle front spring eye brackets......and yes, both sides are bent slightly upward (at the end toward the tire). Looks like each frame rail may be twisted slightly, I agree the brackets are too beefy to bend. Will try a picture Sunday sometime (hopefully).
