Old 06-19-2002, 03:52 PM   #1
Low69CST
5 on 4.5 front rotors?
Anybody ever seen these for our trucks?
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 06-19-2002, 04:53 PM   #2
72chevyLWB
Got 20's????
72chevyLWB's Avatar
5 on 4.5 is a Ford bolt pattern. Ours are 5 on 5 and S-10's are 5 on 4 3/4.
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 06-19-2002, 05:17 PM   #3
Low69CST
I transplanted a different rear end onto my truck, it has a 5 on 4.5 lugs, i was curious if front rotors are easily available to match this for our trucks.
Old 06-19-2002, 05:53 PM   #4
SCOTI
SCOTI's Avatar
You can get the bolt pattern re-drilled in the front rotors to match or buy wheels w/split pattern holes, or re-drill rear axles.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-19-2002, 06:30 PM   #5
ebfabman
I've been thinking about different bolt patterns for our trucks for some time.
The reasons;
(a)I have a real nice set of '86 16" IROC camaro (5x4.75) wheels that I would like to use on a 67-72 chevy truck. Havn't seen it yet but I think it would look pretty cool
Opinions on this???
(b)Many people use 9" ford rears. The linc versailles rear end is 5x4.5. I think some MOPAR rears are 5x4.5 also.
The 5x4.75 bolt pattern is not so hard to deal with. There is a kit that uses pre 71 spindles and bearing spacers to adapt camaro/chevelle rotors. Then redrill the rear axels to the 5x4.75 bolt pattern
5x4.5 may be a little harder to deal with, there may not be enough room on the axel flange to redrill to a larger bolt pattern. Also, what front rotor could be used? mustang ll ??? maybe a different spindle/rotor combo ???( I think this was the original question, sorry no help here)
Seems like the answer would be as stated above to redrill the front rotors, but the hub diameter may be a little big for some wheels to fit over. Something to consider when adapting different wheels.
ebfabman is offline   Reply With Quote
Old 06-19-2002, 07:43 PM   #6
SCOTI
SCOTI's Avatar
When I had my stock 12" truck rotors re-drilled to the car 5x4.75 pattern I had the hub turned down @ the same time.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-19-2002, 08:25 PM   #7
ebfabman
SCOTI, good idea. What'd it cost ya?
Old 06-19-2002, 09:57 PM   #8
Low69CST
Some of the Lincoln rears have a 5x5 pattern.
I put a Chrysler 9.25" rear under my truck because it was freakin massive, had disc brakes and was pretty damn cheap, $200. I thought about converting the rears to a 5x5 pattern, but then you also have to have the rotors drilled as well. I called a few places about redrilling the axles, but nobody round here said they could. I think that it would be much cheaper to get the front rotors drilled than doing it twice in the rear. OK, that doesn't sound right, but you know what I mean.
Old 06-19-2002, 10:57 PM   #9
SCOTI
SCOTI's Avatar
I had a machine shop that does fab work for the dairy plant I work for do it for a favor. I think places like Moser get around 100 bucks to change bolt pattern & turn hubs down (2-rotors)but I'm not 100% sure on that price.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-20-2002, 08:27 AM   #10
Low69CST
Turning the hub down may or may not be nessacary. Some wheels are "hubcentric" and others are "lugcentric" (like my new popular hotrodding lingo??) If the wheels i get are hubcentric then i'd have to machine the hub to match the wheel. If their lug centric then just make sure the wheel will fit over the hub.
