Old 06-17-2005, 11:36 PM   #1
R@nger
Psalm 23
R@nger's Avatar
Alternator electrical question
Ok well at the moment I have my fan shroud and fan off and I'm painting the fan shroud..can't stand the yellow, half painted mess that it has been since I got the truck . Anyways with all the extra room I changed my alternator belt. This got me looking at the HORRIBLE wiring going on in my engine compartment. My question is, where are the wires from the alternator supposed to go? I looked at the wiring diagram posted in the FAQ section but its to complicated because my wiring is so messed up I can't even tell whats what. Right now they have the power from the alternator going to a 4 way pile up where it there continues through one wire across the radiator and into the fusebox maybe???...and then they have a wire connected directly to the positive battery post going across the radiator and again possibly into the fusebox???...its a horrible mess.
Just a little explaination of what wire goes where in the engine compartment would be a huge help...thanks .
71 GMC Fleetside C15(cab), 3/4 ton, 350, Holley Street Avenger 570cfm carb, TH350 trans, Leaf-springs, 2WD.
"Peter are you sleeping on the job? No I have a bug in my eye and I'm trying to suffocate him." - Family Guy
R@nger is offline   Reply With Quote
Old 06-18-2005, 07:20 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
pics?
Old 06-18-2005, 02:19 PM   #3
R@nger
Psalm 23
R@nger's Avatar
Yeah I'll post some today...it was to dark lastnight to take them.
Old 06-18-2005, 06:20 PM   #4
john
member #16
john's Avatar
There are 4 red 12ga wires connected together. See diagram. One goes to the junction block on fender by batt, One to alt One to regulater and one to block on firewall. Plus a 18 ga B/W fused wire for ammeter if so equipped. It might be easier to find another wire loom for eng if yours is hacked up.
john is offline   Reply With Quote
Old 06-19-2005, 06:33 PM   #5
R@nger
Psalm 23
R@nger's Avatar
Ok here some pics
Alt
Where the alt wires go
Wire pile up...there are 4 wires here but one of them is like brown or black I think and its under the tape.
This is to the right of my radiator next to the headlight.
Old 06-19-2005, 07:59 PM   #6
john
member #16
john's Avatar
WOW it looks like it was hacked up when it was rewired for the alt on pass side with long pump and later eng. those should be the alt wires in the first pic. It should have at least a 12ga wire from pos batt to terminal block on the fender. Those red wires in the diagram are tied together inside the loom on drivers side I cant tell what goes where from the pic but I would definatly get another loom and start over. You will still have to rewire for the pass side alt. I think they do make looms for your setup. Possibly painless or a board vender. Good luck John
Old 06-19-2005, 08:46 PM   #7
R@nger
Psalm 23
R@nger's Avatar
Ohh so the alternator is originally supposed to be on the drivers side?
EDIT: The engine is a 77-79...it was swapped shortly before I got it...could that be the reason the alternator is on the passengers side and not the drivers?
I REALLY wish the previous owner would have done his homework and done the job right.
