Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 06-18-2005, 12:01 PM   #1
Hook'em
Hook'em's Avatar
Truck needs wax..what do you use???
Truck needs a good wax job. I'll be heading to the store to pick-up some wax and was wondering what everyone around here used.
Hook'em
Hook'em is offline   Reply With Quote
Old 06-18-2005, 12:04 PM   #2
BAD4X4
BAD4X4's Avatar
I use mothers products.
1972 Cheyenne K-30 6"lift {502 PROJECT}
1972 Cheyenne K-30 8"lift 454 450hp {Ol'Blue}
1972 Cheyenne K-20 Custom Stretch 6" lift 454
1972 Custom Deluxe K-20 4" lift
2007 GMC Crew Cab Diesel 6"lift {The Tow Rig
2017 Ford F-350 Crew Cab 6.7 6"lift (Wife's)
1977 El Camino SS Grandpa baught new
1986 K-30 Crew Cab 502
1955 Chevy 2-Door gasser 454 550hp{project}
1956 Chevy Bel-Air 2-Door hardtop 572 700hp
1979 Ford F-350 All Original 4x4 (Wife's)
BAD4X4 is offline   Reply With Quote
Old 06-18-2005, 12:07 PM   #3
matthufham
meguiars, turtle wax
matthufham is offline   Reply With Quote
Old 06-18-2005, 12:28 PM   #4
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Been using meguires cleaner wax and carnuba wax. Cleaner wax works great but the carnuba wears off so damned fast. Thinking of switching to one of the silicone based products. Drawback of that is paint contamination if some future body/paint work must be done.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 06-18-2005, 12:52 PM   #5
longhorn71
longhorn71's Avatar
longhorn71 is offline   Reply With Quote
Old 06-18-2005, 01:35 PM   #6
Mudder
Mudder's Avatar
M-Ron by California Customs. Can be applied in direct sunlight. Goes on easy and comes off easy leaving no residue. Lasts good. No silicone.
Mudder is offline   Reply With Quote
Old 06-18-2005, 07:20 PM   #7
Long Roof
Old School, New Style
Long Roof's Avatar
Meguires is what I use. It goes on pretty easy and comes off even easier. I question how long it last but the cars I do are not really daily drivers so I probably wax them more than most people.
Has anyone ever used Zaino Bros? I here its the bomb. You have to buy it from a rep. All the Impala guys talk about it on there board.
Aaron
The Good:
- 72 GMC Jimmy 4x4 - 307 cid / 350 th
- 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th
- 96 Chevy Impala SS - mainly stock
- 98 Chevy Tahoe LT 4x4 - all stock
The Bad:
- 86 Chevy Suburban 1/2T 4x4 - winter beater
The Ugly:
- 72 Chevy Suburban 1/2T 2wd - parts truck
Long Roof is offline   Reply With Quote
Old 06-18-2005, 08:00 PM   #8
mocwon
Keep On Truckin'
mocwon's Avatar
3M hand glaze. Not really wax though....
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 06-19-2005, 02:20 AM   #9
4x4Poet
I use DuraShine. No silicone. Goes on as easy as applying Armourall; excess is rinsed off with gentle stream; water sheets off, never beads up to dry in a ring; no wax powder to somehow get out of every crack and crevice. Harmless to all parts of the exterior: paint (duh!), plastic, glass, rubber. On clean, wax-free paint with no oxidation, Durashine shines with a wet luster, though not like an ad might show.
Protects extremely well against UV rays. Best I've ever found for UV protection. The matching Durawash soap has no silicone, either, and has a little Durashine in it so that regular washing touches up the protection. Works fantastic on frames and axles since it can simply be rinsed off. Who wants to buff a frame/axle?
Drawback: Does not have the impact protection that a thick coat of wax can give, however little. Nice trade-off to get Durashine's UV protection and water sheeting qualities. I've found it in K-Mart (yes, that's a drawback).
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 10-02-2005, 09:52 AM   #10
73737373
Meguiars Cleaner/Wax and/or Nu Finish. A barn full of car show trophys using these 2 products.
1968 Custom SWB, 327/3 speed OTC
1969 CST LWB, 402/400
1970 CST LWB, 402/400
1970 Sierra Grande LWB, 350/350
1971 Cheyenne LWB, 350/350
1972 Cheyenne Super LWB, 402/400
1972 Sierra Grande LWB, 402/400
1979 Silverado LWB, 350/350
1984 Suburban
1990 454 SS
1991 Silverado, X-cab, 4.3/5 speed Getrag
2005 Silverado Crew Cab
Corvettes: 75, 77, 78, 93, 96
73737373 is offline   Reply With Quote
Old 10-07-2005, 05:41 PM   #11
gator2511
gator2511's Avatar
I used Meguiars for years on my garaged cars. I started using it on my truck (it lives outside) and it wont bead water after about three weeks. I tried several waxes and believe it or not I found Nu Finish at Wal Mart works great I know its cheap and doesn't have big fancy marketing but it kicks Meguiars a$$ on my outside truck. I wax just about every other month anyway but this stuff lasts and longer finishes slicker than anything else I've used.
gator2511 is offline   Reply With Quote
Old 10-19-2005, 10:57 PM   #12
llegos
Re: Truck need wax..what do you use???
i have used stuff called klasse wax, imported from germany. I would only reccomend it for show as it is very $$$$, but very nice wax nonetheless
-Steve
llegos is offline   Reply With Quote
Old 10-21-2005, 10:24 AM   #13
70c10
67-72 Addict!
70c10's Avatar
I like Meguiars gold class but plan to try the California Customs that Mudder mentioned.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 10-27-2005, 01:59 PM   #14
70chevc10
70chevc10's Avatar
when i worked at a detail shop at a dealership, and all our products were from a company called PRO. ive never seen their products in the stores, but i think you cna order products online here at their website. the finishing wax we used was theri PRO GOld i beleive. they have some really great products. i couldnt find it ont heir site but i highly recomend Pro-Shine for interiors. the BEST stuff we have ever used.
70chevc10 is offline   Reply With Quote
Old 10-28-2005, 03:41 PM   #15
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
All I'll use now is either Zaino (which is a sealer) or Meguiars NXT. The NXT is incredible and easy to find now. Pretty much everywhere.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 12-28-2005, 01:40 AM   #16
wibilly
wibilly's Avatar
try zymol great stuff but expensive but holds up very well about $15 bucks a bottel at walmart
common sense isn't so common anymore
wibilly is offline   Reply With Quote
