Old 06-18-2005, 05:14 PM   #1
smbrouss70
smbrouss70's Avatar
Question Windshield frame differences????
I'm looking at buying a hardtop for my Blazer, but the Blazer it is on right now has 2 curves kinda going into the top right above the windshield, to give some room to mount the sunvisors to the windshield frame. My blazer's W/S frame doesn't have an area to mount the sunvisors, it only has the center curve for the rearview mirror... Were there different tops and winshield frames? Can this top seal to my windshield frrame? Does any of this make any sense?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 06-18-2005, 09:47 PM   #2
2wdBlazer
The Blazer King
2wdBlazer's Avatar
I don't quite picture what you are saying but all tops mount the same in the front. Only bedrails differ on single vs double wall. Maybe your windsheild has been modified somehow?
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 06-18-2005, 10:57 PM   #3
tnblazerk5
User #12137
tnblazerk5's Avatar
can you get pics of what your talkin about ?
tnblazerk5 is offline   Reply With Quote
Old 06-18-2005, 11:51 PM   #4
Gee_Emm
The 5 windshield frames I have/had all look the same.
Here are some pictures for you to compare to.
Gee_Emm is offline   Reply With Quote
Old 06-19-2005, 12:11 AM   #5
smbrouss70
smbrouss70's Avatar
I think this is what I am talking about...(circled red) although now it looks like it is attatched to the windshield frame instead of a part of it. You have to excuse my ignorance on this subject, I am brand new to the Blazer side of things and I am starting out with a tub that is missing just about everything... as seen below.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 06-19-2005, 12:49 AM   #6
jamie72
jamie72's Avatar
those items circled look to me like sunviser brackets??????
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 06-19-2005, 01:14 AM   #7
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Yeah, those are the sunvisor brackets. On the Blazers/Jimmy's they have a hole through them for a bolt that goes to the top. There are also two more metal brackets with two bolts each into the top of the winshield frame and one bolt each into the top. You can see the holes for them in the green windshield frame Gee Emm posted.
The brackets you circled are reproduced to my knowledge. The sunvisor brackets for the trucks/suburban's don't work (they might if you don't ever plan on putting a top on your truck.)
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 06-19-2005, 11:42 AM   #8
jamie72
jamie72's Avatar
if you need the sunviser brackets i got a set. pm me..
jamie
jamie72
member #807
www.antlertalk.com
Old 06-19-2005, 11:51 AM   #9
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Glad to see that blazer got saved by someone.... Should be nice when its done..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 06-19-2005, 01:34 PM   #10
smbrouss70
smbrouss70's Avatar
Thanks guys. I guess there is still a little bit that I need to learn about these Blazers, and I just thought they were trucks that were cut down and had a removable top.
Frenchblue -- it isn't as bad as I thought it was from the pictures, it still needs some work, but nothing I can't handle with you guys help!
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
