Old 06-18-2005, 06:54 PM   #1
67bbchevy
Which frames will fit a 67-69?
I'm having trouble finding a 67 chevy 4x4 short box, so I'm wondering what years of frames could be used to convert a 2 wheel drive truck into a 4x4. I'm also planning on putting a big block with a 4 speed and 3/4 or 1 ton running gear.
67bbchevy is offline   Reply With Quote
Old 06-18-2005, 07:09 PM   #2
pjmoreland
pjmoreland's Avatar
As far as I know, 67-72 is all that will work.
pjmoreland is offline   Reply With Quote
Old 06-18-2005, 09:17 PM   #3
Rod
Thats about it like pjmoreland said...you could attempt to convert a leaf sprung rear swb into 4x4 if you can grab crossmembers, spring hangers..etc from a 4x4...some 67-72 4x4 frames get parted out that are lwb around this board...you ask around here..you'll get what you need eventually.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 06-18-2005, 10:31 PM   #4
Randy70C-10
Randy70C-10's Avatar
Mudder's frame is from a later model (like 80's I believe).
Randy70C-10 is offline   Reply With Quote
Old 06-18-2005, 11:16 PM   #5
Rod
Yep...if your into frame mods you could use a newer GM frame. There longer to start with.
