Old 06-18-2005, 09:04 PM   #1
Tim240Z
Tim240Z's Avatar
71 Cheyenne done *Pics*
Some other pre-completion pics here:
http://67-72chevytrucks.com/vboard/s....php3?t=159857
I got all the moldings installed and the new tonneau cover on. I also installed the new hood hinges....what a difference (previous gap can be seen in the post above)
Here is the completed product. I have put on about 30 miles now and she runs smooth as silk and oil pressure is steady and the temp has not risen above 190* (usually stays right at 185*). The 4L60E overdrive is *****in!!
Hood gap now:
99 Tahoe 2nd row seats:
New dash, sterring wheel and Van tilt column:
Thanks guys for all the tips, both directly and via searching and browsing!!!
1972 Suburban C20
454/TH700R4, eaton-corporate 4.10 (looking for 3.7)
Sold: 71 Cheyenne 20
Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005)
Tim240Z is offline   Reply With Quote
Old 06-18-2005, 09:13 PM   #2
tnblazerk5
User #12137
tnblazerk5's Avatar
looks great !!!!! and i really like the steering wheel that just sets it off
tnblazerk5 is offline   Reply With Quote
Old 06-18-2005, 09:24 PM   #3
Hart_Rod
Hart_Rod's Avatar
Truck looks great! What did the steering wheel come off of? Did you need and adapter to mount it?
Rob
Hart_Rod is offline   Reply With Quote
Old 06-18-2005, 09:37 PM   #4
Tim240Z
Tim240Z's Avatar
It's just a Grant....got it from Summit Racing. It was the only one that seemed somewhat period specific and didn't look cheap and plastic'ey
1972 Suburban C20
Old 06-18-2005, 09:40 PM   #5
Hart_Rod
Hart_Rod's Avatar
Tim, do you have a part number? Also I would like some pics of the engine and tranny. I'm getting ready to do that in swap in my 69 suburban. Did you use an aftermarket harness? Who flashed your computer? Thanks,
Rob
Old 06-18-2005, 09:59 PM   #6
Dick Dale
Excelsior, You Fathead.
Dick Dale's Avatar
Looks good.
Go Navy. The Sea Is Ours.
Budget 350 Build
http://67-72chevytrucks.com/vboard/s...38#post2264638
Dick Dale is offline   Reply With Quote
Old 06-18-2005, 10:02 PM   #7
Tim240Z
Tim240Z's Avatar
Here is the steering wheel at Summit (GRT-697):
http://store.summitracing.com/partde...=KeywordSearch
I bought the TunerCat tuning package (software and cable)...I have used TunerCat before (94 LT1/T56 in my 240Z) and I like the interface....
I adapted the OEM Suburban harness.
Here are some pics (these were during the conversion, I don't have any pics since):
1972 Suburban C20
Old 06-19-2005, 02:29 AM   #8
edmonton72
Nothings as cool as my 72
edmonton72's Avatar
Did the seat mounts line up with the stock ones or did you have to make new mounting locations in the floor.
1972 C10 Longbox
In the middle of body off restoration
Rebuilt 355, turbo 400, 3.42 12-bolt
Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding.
edmonton72 is offline   Reply With Quote
Old 06-19-2005, 05:49 AM   #9
Tim240Z
Tim240Z's Avatar
Some lined up, others I had to drill. I drilled a couple of holes in the seat frame to match existing bolt holes in the floor, and a couple of new holes in the floor...
1972 Suburban C20
Old 06-19-2005, 07:44 AM   #10
70 shorty
Where's my beer?
70 shorty's Avatar
Did you use a glove box door for your gauge panel?
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 06-19-2005, 11:27 AM   #11
Tim240Z
Tim240Z's Avatar
Nah, just cut out a piece of sheet aluminum. I used the original as a template onto cardboard, then transfered to the aluminum.
1972 Suburban C20
Old 06-19-2005, 02:16 PM   #12
phanatic32212
It's Done When It Runs!!
phanatic32212's Avatar
Great driveway job!!! I don't have a driveway but I have a small garage. Wanna come down to San Diego and start working on mine?
Or Give Me DEATH
phanatic32212 is offline   Reply With Quote
Old 06-19-2005, 04:55 PM   #13
Tim240Z
Tim240Z's Avatar
Well....I have 2 other projects waiting in line!
My 73 Opel GT, which is painted, but needs to be gone through mechanically
My 73 Datsun 240Z. It had a 94 LT1/T56 from a Z28, which I sold. I am now building a 357ci SBC with a pair of T04 Garretts and ford 9".
Maybe when those are done........
1972 Suburban C20
Old 06-20-2005, 03:05 AM   #14
TN70C10
Hey on those seats are they power? How did you mount them using their track and frame or you original?
TN70C10 is offline   Reply With Quote
Old 06-20-2005, 06:26 AM   #15
Tim240Z
Tim240Z's Avatar
No power....only the front seats in the Sub/Yukon are power AFAIK. I used the frame from the second row seats, nothing from the original bench seats were used....
1972 Suburban C20
Old 06-20-2005, 09:56 AM   #16
Yukon Jack
Post Whore
Yukon Jack's Avatar
Really sharp - lot of cool things you have done.
That 73 240Z must be a handful - sounds like great plans for it.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 06-20-2005, 10:28 AM   #17
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Good lookin truck.
Weird how your interest parallel mine. I've had 8 or 9 Z's. Was doing a F@#D 5-0/T-5 swap on the last one but discovered a badly tweeked frame and ended up tossing it. Wanted a Manta before them. Never got one. Guy is building one down the way. Tight engine bay...
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 06-20-2005, 04:08 PM   #18
seanu
Too many projects!!!
seanu's Avatar
Tim,
Here's another one....you could have a matched set!
http://cgi.ebay.com/ebaymotors/ws/eB...&category=5348
Sean
1995 Buick Roadmaster Sedan
2004 Chevy Trailblazer 5.3L V8
1963 Chevy Biscayne 4D Sedan
1971 Chevy C10 (now have 70 cab & frame)
1968 Chevy C10 (parts for the 70)
1991 Oldsmobile Custom Cruiser (Chevy 355 motor)
1937 Pontiac 8 4D Touring Sedan (in pieces)
Jacksonville, Florida
seanu is offline   Reply With Quote
Old 06-20-2005, 08:47 PM   #19
timamin
timamin's Avatar
hey I was wondering what seats are those? and how did u get them in? is there an install guide? I have a 72 chevy custom 20 but it would be about the same right? I have a bench seat but those are awsome. I want something like that in it.
'72 custom 20
Current mods
race built chevy 400 engine. over carbed =/
Powder coated bumpers
Progressive Wheels
Future mods
single windows.
alum. fuel cell under bed, sidemarker fuel cap mod.
All white and yellow interior.
leather bucket seats.
timamin is offline   Reply With Quote
Old 06-20-2005, 09:09 PM   #20
Tim240Z
Tim240Z's Avatar
If you read above you will see all the info on the seats. No install guide, but easy to do....
1972 Suburban C20
Old 06-20-2005, 09:13 PM   #21
ratfreak888
man i hope my driveway job looks half as good. nice to see you went fairly stock except for the hood. but i like it keep on truck'n
ratfreak888 is offline   Reply With Quote
