Old 04-12-2002, 10:13 PM   #1
BubbaGreen
Post Spindle questions / drop spindles?
Are there any differences between 71 and 72
model spindles?
I have a '71 and the pass-side spindle looks
to be worn on the outer bearing race, looks
like the nut was left a little too loose and
the bearing seat spun. I have access to some
'72 model spindles, Can I use them?
On the flip side, I can get news ones with a
2.5" drop on the front...which that would be
the absolute max for me ( I really dont care
much for the lowered look ) but doing that
will require lowering the back some. I have
coils, so if I go the drop spindle, is 4"
drop in the rear too much? Can I still use
the stock track-arm, or will it need to be
relocated as well? Then I assume different
shocks...I dont mind doing the work -or-
spending the bucks....Just need to know. My
thinking is, if I lower it the 2.5"/4.0" it
will handle a little better...I already have
a 1-1/4" front sway bar and urathane bushings
I am currently going thru the front end...and
of course, now is the time to do it RIGHT,,,
cause its turning out to be alot of work.
Any thoughts welcome, I needs assistance..
71 Chevy C-10 SWB Fleetside WAS:307w/3-on-the-tree NOW:350TBI/700R4/3.73
See it at www.prismnet.com/~grzanich
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
BubbaGreen is offline   Reply With Quote
Old 04-12-2002, 10:50 PM   #2
70shortnphat
"See the U.S.A....."
70shortnphat's Avatar
Post
Sounds like a good idea to me. If you go to low its just not good for hauling anything and isnt that what trucks are for. I think a 2.5"-3" would be even better.
1970 short bed fleetside
1949 all origional chevy 3600
1974 camaro
Richmond , Texas(just S.W.of Houston)
70shortnphat is offline   Reply With Quote
Old 04-13-2002, 08:13 AM   #3
SCOTI
SCOTI's Avatar
Post
My beater is lowered 5/7 & I pull an 18' car hauler(loaded w/a rolling swb chassis) w/no probs so 2.5/4 should work pretty good w/no capacity issues.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-13-2002, 08:17 AM   #4
BubbaGreen
Post
Well with the stock height...I was gonna put
on P255/70R15 on 15x8 OEM ralley rims, but if
I lower it 2.5"/4.0" (front/rear)...what size
tires would look 'correct' I will put the
same size all the way around, I just like
that look the best. Any body have a side
profile of their truck with a 2/4 drop, I
would really like to see it. Thanks!
Old 04-13-2002, 09:04 AM   #5
SCOTI
SCOTI's Avatar
Post
That size tire(29") should work w/no prob. I've got 215-75-15's(27.75) on 6.5" rallies & even w/it being lowered 5" in front I only rub when I hit a speed bump or big dip in the road going too fast(once or twice in 2yrs). That combo should fill those wheelwells up nicely. Check w/Early Classics on the home page as they should have profile pics of a 2/4 drop.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-13-2002, 11:56 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
Your pan hard bar will probably bo ok, however, it will off set the rear just a little. You might have rubbing problems on one side if you go with rel wide tires and when loaded.
I think Early Classics has an adjustable one.
The '72 and '72 spindles are the same if you decide to keep it stock.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
