Old 06-18-2005, 10:12 PM   #1
smokinn
smokinn's Avatar
tail gate
Any ideas on how to keep my tail gate from making so much noise when im driving it? It seems to be pretty tight.
smokinn is offline   Reply With Quote
Old 06-19-2005, 10:24 AM   #2
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
Are the rubber bumpers still present and accounted for? You could also get some thich rubber sheet and cut some small squares and glue them on over the contact areas.
NeCrOmAnCeR is offline   Reply With Quote
Old 06-19-2005, 01:59 PM   #3
SSC's76
No No
SSC's76's Avatar
Like mentioned above check all the rubber stops. Also you can take the rods out of the inside since they like to jiggle around and make noise and put some of the apropriate size vacuum/fuel line over the rods in a few choice spots.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 06-19-2005, 07:22 PM   #4
augie
Waiting for Paul to Open Safe
augie's Avatar
re:tailgate
Not sure what year your truck is, but I have found that sometimes the metal hinges which hold your tailgate when it's open have a tendency to bang around when the tailgate is closed. I put a little weatherstripping in the channel where they hang while they are closed and it helped a lot.
augie is offline   Reply With Quote
Old 06-19-2005, 11:06 PM   #5
smokinn
smokinn's Avatar
Its a 79, Thanks for all the helpful info. I'll try some and let you know how it works.
Jason
