Old 06-18-2005, 10:23 PM   #1
phanatic32212
It's Done When It Runs!!
phanatic32212's Avatar
Weird Idle Question
Good news: I got my rocker arms installed and adjusted, then went out for a Saturday afternoon drive.
Bad news: The truck ran good before I started all of this, now it wants to die at stop lights at idle. It seems if I don't have my foot on the gas it will die. It started out that it ran fine at idle when in park and any gear for that matter. Now, after a quick drive, it will die in idle no matter what gear. It seems to stay running longer with no load on the engine but still dies sooner or later. The truck sat for a little while without running (a month?). Bad gas, maybe? Fuel pump? Any ideas would be appreciated.
Thanks in advance.
Or Give Me DEATH
phanatic32212 is offline   Reply With Quote
Old 06-18-2005, 10:51 PM   #2
tnblazerk5
User #12137
tnblazerk5's Avatar
Thanks in advance.
kinda sounds to me like everything got broke in sum !!! reset the timing and see if that helps if it dont adjust the rockers again and reset the timing
tnblazerk5 is offline   Reply With Quote
Old 06-19-2005, 11:44 AM   #3
hgs_notes
GEARHEAD
hgs_notes's Avatar
If the new rockers have a higher ratio to open the valves further, it will effect bottom end power and may require more timing advance and a higher idle speed. It effects manifold vacuum which can effect the idle mix on the carb also. Just sounds like it needs a little more tuning.
HG
hgs_notes is offline   Reply With Quote
Old 06-19-2005, 02:09 PM   #4
phanatic32212
Thanks for all of the info. I bought the same rockers that were in before, so I think maybe it just needs a some quality time with the timing light. At least its drivable. Feels so good to have it back out on the road. Thanks Again
Jake
Or Give Me DEATH
Old 06-20-2005, 01:36 AM   #5
tomatocity
tomatocity's Avatar
check for a bad vacuum line.
Thanks in advance.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 06-20-2005, 01:37 AM   #6
tomatocity
tomatocity's Avatar
make sure the distributor did not slip and change the timimg.
Thanks in advance.
Old 06-20-2005, 03:08 AM   #7
71Dragtruck
71Dragtruck's Avatar
Just incase you didn't, make sure you adjust your rockers with the engine hot
71Dragtruck is offline   Reply With Quote
Old 06-20-2005, 05:57 PM   #8
phanatic32212
Hmmmm, I went out yesterday and the thing ran fine. I checked everything anyway and it all looks good. Thanks for all of the tips.
Or Give Me DEATH
