Old 06-18-2005, 10:43 PM   #1
skokie
skokie's Avatar
Burn on intake Manifold
I was checking the oil and I noticed this. Has anyone had this happen to them? Is this a exhaust leak? I checked the bolt and its good and tight. I also checked the wire and it is not touching the intake.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 06-18-2005, 11:13 PM   #2
Sweet72
Sweet72's Avatar
That's where the exhaust crossover is on the intake. It could be a leaky intake gasket, but probably not, the exh. crossover area gets extremely hot, nearly as hot as your exhaust manifolds and will eventually burn off most engine paints.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 06-19-2005, 06:03 AM   #3
OhioDan
OhioDan's Avatar
Thumbs up
Didn't they used to sell, or maybe they still do(?), sell intake manifold gasket sets with a steel blank to cover that hole? Thought I remembered seeing those a long time ago?
Or, is my OFS (Old Fart Syndrome) acting up again?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 06-19-2005, 06:20 AM   #4
GMC AMI
GMC AMI's Avatar
Yup, they still have them!
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 06-19-2005, 01:26 PM   #5
midyearvet@aol.
Gaskets
Try Summit or another speed parts house.
Rick / Ca.
midyearvet@aol. is offline   Reply With Quote
Old 06-19-2005, 02:10 PM   #6
Green Machine
Green Machine's Avatar
NAPA has them also, in any flavor you want, Victor gaskets I think. Don't know part numbers but they can find them. There is the completly open style, ones with a 1/2 inch restrictor plate, and complely blocked. In Cali, you may not need much heat under there, in colder areas some heat is desirable for cold operation, also if you have EGR to be emmisions legal you need to have some exhaust available under there. You can mix and match gaskets also. Fully open on both sides gives most heat,(and the most most burned paint) older SBC were that way. Your choke spring may be heated from this also. One combination that may work is to block the drivers side, and use the 1/2 restrictor on pass side to warm choke spring.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 06-19-2005, 03:34 PM   #7
tmcgrawlookalike
felpro has them.they have it where you can partially block off the ports,or completely.if you look in the catalog,or on their computer,tell them it`s for a propane powered engine.they come blocked off completely.nothing at all/no hole/nada!!!i used to sell the sh%# out of these to racers that wanted a stock type gasket with that blocked off,and they are cheaper than mr.gasket,edelbrock,etc.....it`s also what i run on mine,and they do great.good luck!!
tmcgrawlookalike is offline   Reply With Quote
