Old 06-19-2005, 07:43 AM   #1
pedrofixlater
75 STEPSIDE
pedrofixlater's Avatar
Angry Help Hood
Just got my stepper and the @#$%^& hood folded up like an accordian.
I knew i should have supported it since my old 78 i had years ago did the same thing.
Does anyone make the weeker springs for our trucks. I have seen them for fiberglass hood for the classic cars.
Of course this happens two days after getting mine out of the paint shop
now i need a hood and the weaker springs and paint
Pete
75 Chevy Stepside
70 Buick Skylark/GS
pedrofixlater is offline   Reply With Quote
Old 06-19-2005, 09:22 AM   #2
us111
hood
now that !@#$%^&* suck's!!!! personally i have never heard of a weaker spring. (don't mean they don't make them though).mine done same thing,i learned that it's by design,so if your in a wreck the hood buckles easy..everyone has told me the best thing to do was get new arms,spring's etc. and be sure to keep greased good,,know that don't help you any but that's what everyone told me the fix was...
us111 is offline   Reply With Quote
Old 06-19-2005, 10:11 AM   #3
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
Some companies make "mend plates" to support the hood alond the fild line. But since you are going to get a new hood, it would be best to replace the hinges as mentioned above. If you do use weaker springs you will need to use a prop rod to hold the hood open.
NeCrOmAnCeR is offline   Reply With Quote
Old 06-19-2005, 10:54 AM   #4
slingin mud
Mark
slingin mud's Avatar
well get rid of springs and get after market prop rod . even if you had a fiberglass hood they have to come off
Look at every day as a holiday, some just better than others.Build what you got be happy with what you have This truck is for sale
slingin mud is offline   Reply With Quote
Old 06-19-2005, 11:18 AM   #5
jermasaurus
jermasaurus's Avatar
Check out some hood/hatch support shocks for other cars. I'm sure you could make those work, but they are also very hard to compress. I guess you would have to think out where to mount them to avoid that again.
jermasaurus is offline   Reply With Quote
Old 06-19-2005, 01:02 PM   #6
corn
If you have your mind made up to get lighter springs, you will still have to get a prop rod. If you buy a fiberglass hood you can get by with light springs but the factory springs & hood are a matched set. I say, keep your hinges lubed up & you wont have to worry about it. Sorry to hear yours gave it up right after paint, that sucks...corn
corn is offline   Reply With Quote
Old 06-19-2005, 07:26 PM   #7
BowTieMan
BowTieMan's Avatar
I read that with the fiberglass hoods they recamend and some componies that make the hoods sell lighter springs.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 06-19-2005, 09:43 PM   #8
TrainD5115
North Coast, baby!
TrainD5115's Avatar
Don't waste your time with the hood brackets. They are a waste of twenty dollars. I have them under my hood and they lasted about two closes before they folded too. They are way too flimsy to be of any real help. I would suggest having some made out of a sturdy material or going with the prop hood.
Brad
79 Scottsdale C20
350/350
3.73's
Still running full CA smog gear!
TrainD5115 is offline   Reply With Quote
Old 06-19-2005, 10:58 PM   #9
Lynx
Lynx's Avatar
Cant you use later model hinges? I know they changed the style of hinge and they didnt have any problems with it.
Ben
1983 Silverado SWB 305
2002 Silverado Extended Cab 5.3
http://members.shaw.ca/bkennett
Lynx is offline   Reply With Quote
Old 06-19-2005, 11:31 PM   #10
us111
hinges
it's not the hinge's so much (although you have to take care of them) as the design in the hood's that were made to "buckle" under pressure.. the brace's you see are a waste of good money.. they will not fix the problem...new hinge's,,good lube,,new hood,,carefull closing is the only answer i have found if you want to use the original style hood...but like i said,,it's the only answer (i have) found.....
Old 06-19-2005, 11:56 PM   #11
SSC's76
No No
SSC's76's Avatar
I had this happen, even had the support straps, its not the springs fault usually its just worn hinges. If your set on lighter springs like I was because I was in denile at the time look for a early 80's caprice, they will have the ones you want and will have enough tension to hold the hood up.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 06-21-2005, 01:39 PM   #12
mhicks
mhicks's Avatar
Oil the hinges and keep them oiled and there won't be a problem
mhicks is offline   Reply With Quote
Old 06-22-2005, 02:50 PM   #13
86-C10-V6
Shadetree Mechanic
86-C10-V6's Avatar
Make sure the hood still has the glue holding the sheetmetal to the support frame. Mine had broken loose in several places, the hood bounced as I drove along. Used some construction adhesive to re-glue and the hood is much stiffer now, no more bounce.
Dave M. (Hacksaw)
86 C10 Scottsdale LWB, 4.3L, Edelbrock 1904, K&N, 700R4, 3.08 Auburn Performance
89 GMC S-15 Extended Cab 4x4, 4.3L, FI
98 K1500 Xcab, 5.7L, 3.43 Gov-Lok
86-C10-V6 is offline   Reply With Quote
